Tim Michelsen wrote:
There exist v.external and r.external to link to data which
hasn't been imported into GRASS.
But in order to save time and disk space I would like to
link to data sets from other locations:
How do I link to a raster and vector data in another
location presuming it has the same projection?
add the mapset as a symlink to the mapset in the other location,
then use the @othermapset notation.
(at your own risk)
Hamish
A related issue – I’d like to use r.external but I can’t seem to get it to work. I’m running wxPython for GRASS 6.4 (from the Osgeo4W installation). r.external seems to work properly, but when I try to display the result, I get an error message telling me that GDALAllRegister can’t be found. Here, I’ve reproduced this in the spearfish60 dataset:
r.out.gdal input=elevation.10m output=elev_dem10.img format=HFA type=Float32
r.external input=elev_dem10.img output=elev_dem10_rext
d.rast map=elev_dem10_rext
The layer shows up in the layer manager as “raster (double-click to set properties)”. I double-click and the name changes to elev_dem10_rext@user1…
Then I try to Zoom to Layer, or click on the Display Map button and I get:
Execution fiailed: ‘d.rast.exe map=elev_dem10_rext@user1 --q’
Details:
Error: Unable to locate symbol
(By the way, I’ve also encountered this error message trying to do r.mapcalc on a GRASS file imported using r.in.gdal.)
Has anyone encountered this error? Is there a way to fix it?
Matt
Hamish wrote:
Matthew Landis, Ph.D.
Research Analyst
ISciences, LLC
61 Main St.
Burlington VT 05405
802.864.2999
So sharing data between locations is not really supported?
Even if I just want to add the layer to the map view?
Timmie
View this message in context: http://n2.nabble.com/link-to-datasets-from-other-locations--tp3185792p3188925.html
The only operations which access data in a different location are
those where the data is necessarily in a different location because it
uses a different projection, e.g. re-projection or rectification.
In general, if it's possible for the data to be in the current
location, then it must be.
As GRASS is aim to support Windows, this is not an option
On Wed, Jul 1, 2009 at 2:03 PM, Matthew Landis<landis@isciences.com> wrote:
A related issue -- I'd like to use r.external but I can't seem to get it to
work. I'm running wxPython for GRASS 6.4 (from the Osgeo4W installation).
get an error message telling me that GDALAllRegister can't be found. Here,
I've reproduced this in the spearfish60 dataset:
I contacted FrankW about this, here his answer:
On Mon, Jul 6, 2009 at 3:17 AM, Frank Warmerdam<warmerdam@pobox.com> wrote:
I have upgraded my OSGeo4W GRASS 6.4.0svn install to the latest available
from OSGeo4W and then tried running r.external and it appears to work fine.
I have also run depends.exe on r.external.exe and it properly depends on
gdal15.dll so there is no reason it wouldn't normally pick up the copy in
C:/OSGeo4W/bin.
If someone had another copy of gdal15.dll in c:/windows/system32 it might
get used instead of the proper one and cause problems though I don't know
why it would be missing gdalallregister.
Sorry I was unable to find anything helpful.
