[GRASS-user] linking different tables to one vector file...
I wanted to ask if its possible to link different tables to a vector map with points, lines and areas (i.e link nodes to node_table, lines to lines_table and areas to area_table).
Jaime
¡Capacidad ilimitada de almacenamiento en tu correo!
No te preocupes más por el espacio de tu cuenta con Correo Yahoo!:
http://correo.espanol.yahoo.com/
2008/1/15, Jaime Carrera <jaicarrerahdez@yahoo.com>:
yes, it is possible. Vector map can be multi-layered. In your case
first sub-layer can contain points, the second lines, etc. You can
link different tables to sub-layers using v.db.connect. In your case
you just need to separate vector types to the different sub-layers.
Martin
Martin Landa <landa.martin@gmail.com> * http://gama.fsv.cvut.cz/~landa *
may be the attached scheme is of some help.
Greetings
A.Clerici
-----Messaggio originale-----
Da: grass-user-bounces@lists.osgeo.org
[mailto:grass-user-bounces@lists.osgeo.org] Per conto di Martin Landa
Inviato: martedì 15 gennaio 2008 9.03
A: Jaime Carrera
Cc: grass-user@lists.osgeo.org
Oggetto: Re: [GRASS-user] linking different tables to one vector file...
Martin
grass-user mailing list
(attachments)
Scheme.pdf (10.5 KB)
