[GRASS-user] Linking raster map instead of copying - alternative to r.reclass?
Hi
I want to be able to acess the same raster map by using two different names, e.g. “map_2007” and “map”.
Is there a way of achieving this (under Linux)? I am using r.copy at the moment, but it uses quite a bit of hdd space (I have many maps!). I could use r.reclass,
r.reclass input=map_2007 output=map rules=???
but what do I put in ??? Which rules do I use?
but is there an easier way of achieving this?
In addition, would r.reclass be dynamic, i.e. if map_2007 is changing, will that be reflected when I access map?
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax (F): +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer@krugs.de
Skype: RMkrug
