[GRASS-user] Linking raster map instead of copying - alternative to r.reclass?
Rainer wrote:
I want to be able to acess the same raster map
by using two different names, e.g. "map_2007" and
"map".
Is there a way of achieving this (under Linux)? I
am using r.copy at the moment, but it uses quite
a bit of hdd space (I have many maps!). I could
use r.reclass,
r.reclass input=map_2007 output=map rules=???
put in a file, or read from stdin:
note r.reclass is only intended to work with CELL
(categorical) maps.
In addition, would r.reclass be dynamic, i.e. if
map_2007 is changing, will that be reflected when
I access map?
yes, although only categories present when the
original r.reclass command was run would be
considered. (e.g. if the range expands the reclass
table won't know about that)
alternatively, you might try a big pile of symlinks.
(probably much easier for vector maps)
Hamish
On Thu, Oct 13, 2011 at 3:49 PM, Hamish <hamish_b@yahoo.com> wrote:
by using two different names, e.g. “map_2007” and
“map”.
use r.reclass,
(categorical) maps.
that might be a problem in my case.
I access map?
table won’t know about that)
would this be a problem if I use "* = "?
I think I’ll go that way - I just thought there would be a solution available.
So which files would I need to symlink? Asked otherwise: in which directories can be raster map related files?
Rainer
Hamish
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax (F): +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer@krugs.de
Skype: RMkrug
> > I access map?
Yes. The "*" is expanded when r.reclass is run, not when the reclass
map is accessed.
I think I'll go that way - I just thought there would be a solution
available.
directories *can* be raster map related files?
cellhd, cell, fcell, cats, colr, hist, cell_misc
On Fri, Oct 14, 2011 at 3:05 PM, Glynn Clements <glynn@gclements.plus.com> wrote:
I access map?
Yes. The “*” is expanded when r.reclass is run, not when the reclass
map is accessed.
OK - so I can’t use it.
available.
Thanks - I will then write my own little script.
Rainer
South Africa
Skype: RMkrug
