[GRASS-user] lion osx
Hi Salvatore,
With William's help, I've been doing some test of GRASS on Lion. Here is what I've found out.
1. GRASS compiled under Snow Leopard runs find on Lion. I've not yet run into any problems, including with the TclTk aspects.
2. GRASS will compile under Lion if you force it to 32 bits, Python 2.6, and wxPython 2.8. This version will run fine on Lion.
3. GRASS 7 compiled under Lion as in #2 seems to run fine under Snow Leopard
4. GRASS 6.4.2 compiled under Lion as in #2 still wants to use Python 2.7 and the GUI won't launch. However, if you force it to start up in 32 bits, it will run fine.
Michael
______________________________
C. Michael Barton
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671(SHESC), 480-727-0709 (CSDC)
www: http://csdc.asu.edu, http://shesc.asu.edu
    http://www.public.asu.edu/~cmbarton
On Oct 25, 2011, at 3:18 AM, grass-user-request@lists.osgeo.org wrote:
Date: Mon, 24 Oct 2011 16:37:19 -0500
Subject: Re: [GRASS-user] lion osx
To: Salvatore Mellino <salvatore.mellino@gmail.com>
Cc: grass-user@lists.osgeo.org
Message-ID: <5415285E-E33D-439C-95E6-E9FFA0AC7099@kyngchaos.com>
Content-Type: text/plain; charset=us-ascii
Not anything specific. The Snow Leopard package should work fine, mostly.
The main difference and problem is Python and the wxPython GUI. The Snow package uses Python 2.6 and a Carbon-based wxPython. While it seems to work on Lion, it's possible there are hidden problems due to Carbon supposedly being stripped out of Lion (I could be wrong on that).
Lion needs a Cocoa-based wxPython, but the GUI doesn't run at all yet. So it's a work in progress.
On Oct 24, 2011, at 4:27 PM, Salvatore Mellino wrote:
is there a specific release of GRASS for LION OS (6.4.2 or 6.5)?
Thanks.
Salvatore
grass-user mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"History is an illusion caused by the passage of time, and time is an illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
