Greetings
I have a raster map with a lot of values and I want to retrieve a list of the existing values. How can I do that in GRASS?
Thanks
Nikos
Greetings
Thanks
Nikos
Am Dienstag, den 20.07.2010, 14:14 +0100 schrieb Nikos Dumakis:
Greetings
Thanks
Nikos
Hi Nikos,
r.stats will do this job
Best,
Manfred
grass-user mailing list
grass-user@lists.osgeo.org
Greetings Dr. Redslob
I have opened r.stats and I cannot find any method/option to print existing values. It prints numbers of values between ranges of values among others but no list of values. Or am I missing some option?
Thank you
Best regards
Nikos
On Tue, Jul 20, 2010 at 2:06 PM, Dr. Manfred Redslob <redslob@gdf-hannover.de> wrote:
Greetings
Thanks
NikosHi Nikos,
Best,
Manfred
2010/7/20 Nikos Dumakis <nikosdu1980@gmail.com>:
-1 One cell (range) per line
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
Greetings
In my case I have not more than 1200 different cell values. If I do :
r.stats -1 input=data
I obtained a list of all pixel values but what I am lookinf is for the unique values (not repeated).
I just need the unique values not all values (repeated)
(maybe I was not clear in my previous messages… I’m sorry
On Tue, Jul 20, 2010 at 2:38 PM, Martin Landa <landa.martin@gmail.com> wrote:
but no list of values. Or am I missing some option?-1 One cell (range) per line
Martin
as mentioned in Hamish's response, use combination of `sort` and `uniq`
r.starts -1 input=data | sort | uniq
Martin
THanks Martin. It works
Just one last question. This is applying Shell Scripts right? Can I do the same but with Python Scripts
On Tue, Jul 20, 2010 at 4:17 PM, Martin Landa <landa.martin@gmail.com> wrote:
unique values (not repeated).as mentioned in Hamish’s response, use combination of
sort
anduniq
Martin
hELLO all
Regarding the use of r.stats -1 input=image | sort | uniq
I have sent a message saying that this works just fine but…
I have only tested in WinGRASS 6.4.RC6). When I tried in Linux (GRASS6.4.0RC6) I got this error:
Sorry <|> is not a valid option
Sorry is not a valid option
Why do I obtain different results in Win and in Linux? and How can I do this in Linux?
Thanks
Nikos
sort
anduniq
Martin
Nikos Dumakis:
shorter:
r.starts -1 input=data | sort -u
Nikos
> `sort` and `uniq`
> r.starts -1 input=data | sort | uniqshorter:
AFAIR, those are not the same thing and can not be used
interchangeably. (although I don't fully remember why right now)
anyway, for floating point maps I still think it's a bad idea.
I'm sure there is a Python equivalent of 'sort|uniq', but don't
know what it is.
'sort' and 'uniq' are UNIX command line power tools and not
available in MS Windows. But.. the MSys command prompt that
ships with WinGrass supplies them and you can use them there.
I suppose the "bin" dir where they are kept are not part of the
gui's PATH which is why they wouldn't work from the Cmd> gui
prompt.
Hamish
> > `sort` and `uniq`
Nikos:
> shorter:
It has troubled me as well (now and in the past). I did (before posting the
above) a quick test using a column from a vector map containing strings. I
counted the result from both "uniq" and "sort -u" with "| wc -l". The results
were identical.
So... :-? Maybe it is ok for strings/integers(?). One should be more careful
with those "knifes".
Nikos
know what it is.'sort' and 'uniq' are UNIX command line power tools and not
prompt.
> > > `sort` and `uniq`
Nikos:
> > shorter:
Hamish:
Nikos:
results were identical.So... :-? Maybe it is ok for strings/integers(?). One should be more
careful with those "knifes".
Hamish:
> know what it is.
> prompt.
Here some details from "(coreutils.info.gz)sort invocation":
`-u'
`--unique'
Normally, output only the first of a sequence of lines that compare
equal. For the `--check' (`-c' or `-C') option, check that no
pair of consecutive lines compares equal.
This option also disables the default last-resort comparison.
The commands `sort -u' and `sort | uniq' are equivalent, but this
equivalence does not extend to arbitrary `sort' options. For
example, `sort -n -u' inspects only the value of the initial
numeric string when checking for uniqueness, whereas `sort -n |
uniq' inspects the entire line. *Note uniq invocation::.
Nikos
On Friday 23 of July 2010 08:58:09 Nikos Alexandris wrote:
> > > > `sort` and `uniq`
> > > > r.starts -1 input=data | sort | uniqNikos:
> > > shorter:
> > > r.starts -1 input=data | sort -uHamish:
> > interchangeably. (although I don't fully remember why right now)Nikos:
> the above) a quick test using a column from a vector map containing
> strings. I counted the result from both "uniq" and "sort -u" with "| wc
> -l". The results were identical.
> careful with those "knifes".Hamish:
> > know what it is.
> > prompt.Here some details from "(coreutils.info.gz)sort invocation":
`-u'
`--unique'
pair of consecutive lines compares equal.This option also disables the default last-resort comparison.
And something more from "man uniq" (a reminder to avoid using "uniq" on its
own):
Note: 'uniq' does not detect repeated lines unless they are adjacent. You may
want to
sort the input first, or use `sort -u' without `uniq'. Also,
comparisons honor the
rules specified by `LC_COLLATE'.
Nikos
