is there any possibility to download data into local grass database (topologcal) from remote postgis server? (without getting error)
Or is the issue still pending? (http://osgeo-org.1560.x6.nabble.com/Unable-to-link-to-postgis-postgresql-td5285313.html)
I am using Python to work with GRASS. And honestly, I got lost in outputs of db.* functions:
#set database and login
gscript.run_command(‘db.connect’, database=“host=172.21.3.20,dbname=mydb”, driver=“pg”, verbose = True)
gscript.run_command(‘db.login’, user=“dbusername”, password=“passwd”, overwrite = True)
#verifying connection
gscript.run_command(‘db.connect’, flags=‘p’)
output:
driver: pg
database: host=172.21.3.20,dbname=mydb
schema:
group:
#so everything looks fine so far
#here comes the trouble - simple list tables in db
gscript.run_command(‘db.tables’, flags=‘p’, verbose = True)
output:
DBMI-PostgreSQL driver error:
Connection failed.
could not connect to server: No such file or directory
Is the server running locally and accepting
connections on Unix domain socket “/var/run/postgresql/.s.PGSQL.5432”?
Connection failed.
ERROR: Unable to open database <host=172.21.3.20,dbname=mydb>
#but for example:
gscript.run_command(‘v.external’,
input=“PG:dbname=mydb host=172.21.3.20”,
flags=‘l’, overwrite = True)
output:
–actuall list of all tables in mydb - so i CAN connect to the server!
#same for mapping external link - following will create external link
input=“PG:dbname=mydb host=172.21.3.20 user=dbusername password=password”,
layer=“myschema.mytable”, output='outpoints, overwrite = True)
output:
WARNING: No key column detected.
WARNING: Feature table has no primary key defined. Unable to
define DB links.
WARNING: Random read is not supported for this layer. Unable to build
topology.
v.external complete. Link to vector map created.
#weird, because i have primary key defined in the table, following is printing description of that external link
gscript.vector_info(“outpoints”)
#if i try to load data from database
gscript.run_command(‘v.in.ogr’,
layer=‘myschema.mytable’,geometry=“mygeomcolumn”, output = “outpoints2”, overwrite = True, type=“point”)
output:
Check if OGR layer <myschema.mytable> contains polygons…
100%�����
WARNING: Vector map <outpoints2> already exists and will be overwritten
Connection failed.
Connection failed.
WARNING: Unable to open database <host=172.21.3.20,dbname=macfishdb> by
driver
WARNING: Unable open database <host=172.21.3.20,dbname=macfishdb> by driver
WARNING: Unable to find table linked to vector map <lp_grass>
Creating attribute table for layer <at_macfish.loggerpos>…
Connection failed.
Connection failed.
WARNING: Unable to open database <host=172.21.3.20,dbname=mydb> by
driver
ERROR: Unable to open database <host=172.21.3.20,dbname=mydb> by
driver
My version of grass:
GRASS version: 7.4.0
GRASS SVN revision: exported
Build date: 2018-01-26
Build platform: x86_64-pc-linux-gnu
GDAL: 2.2.2
PROJ.4: 4.9.2
GEOS: 3.5.1
SQLite: 3.11.0
Python: 2.7.12
wxPython: 3.0.2.0
Platform: Linux-4.4.0-112-generic-x86_64-with-Ubuntu-16.04-xenial
Version of python:
Python 2.7.12 64bits
Content of my .grass7/dblogin:
pg|host=172.21.3.20, dbname=mydb|dbusername|passwd||
sqlite|$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db|dbusername|passwd||
pg|macfishdb|dbusername|passwd||
pg|host=172.21.3.20,dbname=mydb|dbusername|passwd||
Thank you for any comment
Dead Vil
