Hi everybody,
I want to load GeoJSON data in GRASS. I am totally unware of the process. Could anybody please help me to do that?
Thanks & Regards
Arighna Roy
Hi everybody,
Thanks & Regards
Arighna Roy
here is a basic answer to start with.
On Sun, Oct 5, 2014 at 8:44 PM, Arighna <roy.arighna@gmail.com> wrote:
Hi everybody,
I never tried GeoJSON but with recent enough GRASS GIS and GDAL/OGR, you can use v.in.ogr module (module for import of vector data using OGR).
You can use
v.in.ogr -f
to list all available formats. For me it gives “GeoJSON (rw): GeoJSON”.
Something like:
v.in.ogr dsn=/path/to/data/file.json output=grass_vector_map
should work. I don’t know how it is with layers and features but you will see I guess.
Let us know if it work and if you have any problems.
Vaclav
Thanks & Regards
Arighna Roy
grass-user mailing list
grass-user@lists.osgeo.org
Hi Vaclav,
I have loaded the point in GRASS. But the attributes are not loaded successfully. I am posting one sample data. Could you please help me finding what is wrong with the data. Or maybe I am going wrong with the loading process.
“type”: “Point”,
“coordinates”: [50.922759,-90.089954],
“current_conditions”:
“air_temp”:{“unit”:“F”,“value”:32.0},
“cloud_cover”:{“unit”:“%”,“value”:92.8},
“descriptors”:
“cloud_cover_descriptor”:{“code”:20500,“icon”:“http://icons.clearpathapis.com/en-us/style1/v1/128/cover_cloudy.png",“text”:"Cloudy”},
“precipitation_descriptor”:{“code”:61100,“icon”:“http://icons.clearpathapis.com/en-us/style1/v1/128/precip_flurries.png",“text”:"Flurries”},
“visibility_obstruction_descriptor”:{“code”:10500,“icon”:“http://icons.clearpathapis.com/en-us/style1/v1/128/error_none.png",“text”:"None”},
“weather_descriptor”:{“code”:61100,“icon”:“http://icons.clearpathapis.com/en-us/style1/v1/128/precip_flurries.png",“text”:"Flurries”},
“wind_direction_descriptor”:{“code”:51800,“icon”:“http://icons.clearpathapis.com/en-us/style1/v1/128/direction_w.png",“text”:"West”}
“dew_point”:{“unit”:“F”,“value”:32.0},
“ice_acc_last_hour”:{“unit”:“in”,“value”:0.0},
“liquid_acc_last_hour”:{“unit”:“in”,“value”:0.0},
“msl_pressure”:{“unit”:“mb”,“value”:994.0},
“precip_acc_last_hour”:{“unit”:“in”,“value”:0.002},
“relative_humidity”:{“unit”:“%”,“value”:91.0},
“snow_acc_last_hour”:{“unit”:“in”,“value”:0.01},
“station_pressure”:{“unit”:“mb”,“value”:946.0},
“u_wind_speed”:{“unit”:“mph”,“value”:4.8},
“v_wind_speed”:{“unit”:“mph”,“value”:0.9},
“valid_time_end”:1412667600.0,
“valid_time_start”:1412664000.0,
“visibility”:{“unit”:“mi”,“value”:10.0},
“wind_direction”:{“unit”:“degrees”,“value”:260.0},
“wind_speed”:{“unit”:“mph”,“value”:7.0}
Thanks in advance
Arighna
Sent: Monday, October 06, 2014 10:28 AM
To: ‘Vaclav Petras’
Subject: RE: [GRASS-user] Loading JSON data in GRASS
Hi Vaclav,
I have found the module and found GeoJSON in there. I will try to load the data and will definitely post you once get success.
Arighna
Sent: Sunday, October 05, 2014 10:56 PM
To: Arighna
Cc: GRASS user list; Moritz Lennert
Subject: Re: [GRASS-user] Loading JSON data in GRASS
Hi everybody,
You can use
v.in.ogr -f
Something like:
Vaclav
Thanks & Regards
Arighna Roy
On 21/10/14 04:38, Arighna wrote:
Hi Vaclav,
loading process.
This sample data is not enough. According to the ogr GeoJSON format manual [1], "according to the GeoJSON Specification, only the Feature object must have a member with name properties. Each and every member of properties is translated to OGR object of type of OGRField and added to corresponding OGRFeature object."
In other words: attributes have to be members of the member properties of the Feature object.
I can get a bit further in importing your attributes by using the following at the beginning
{"type": "Feature",
"geometry":
"type": "Point",
"coordinates": [50.922759,-90.089954]
"properties":
"air_temp":{"unit":"F","value":32.0},
[then the rest is identical to JSON code].
However, this imports the attributes as such (example is air_temp):
{ "unit": "F", "value": 32.0 }
If I change the JSON to
"properties":
"air_temp":32.0,
etc
I get the expected attribute values, i.e. air_temp is 32.0 which is recognized as double precision in the attribute table.
To check quickly how ogr parses the attributes, you can check on the command line with
ogrinfo point.json OGRGeoJSON
Moritz
Awesome man. It worked now. Thanks a ton Moritz.
Arighna
-----Original Message-----
From: Moritz Lennert [mailto:mlennert@club.worldonline.be]
Sent: Wednesday, October 22, 2014 7:16 AM
To: Arighna; 'Vaclav Petras'
Cc: grass-user@lists.osgeo.org
Hi Vaclav,
OGRFeature object."
the Feature object.
at the beginning
{"type": "Feature",
"geometry":
"type": "Point",
"coordinates": [50.922759,-90.089954] },
"properties":
"properties":
"air_temp":32.0,
etc
line with
Moritz
I am not sure how I can load multiple data in the same map. Putting
everything in the same json file does not work. Also, using an existing map
for loading a new json file does not work.
Sent: Wednesday, October 22, 2014 1:52 PM
To: 'Moritz Lennert'
Cc: grass-user@lists.osgeo.org; 'Vaclav Petras'
Arighna
Hi Vaclav,
OGRFeature object."
the Feature object.
at the beginning
{"type": "Feature",
"geometry":
"type": "Point",
"properties":
"properties":
"air_temp":32.0,
etc
line with
Moritz
for loading a new json file does not work.Import individual JSON files separately and then patch (merge) them using
v.patch.
http://grass.osgeo.org/grass70/manuals/v.patch.html
Subject: RE: [GRASS-user] Loading JSON data in GRASSAwesome man. It worked now. Thanks a ton Moritz.
Arighna
Subject: Re: [GRASS-user] Loading JSON data in GRASSOn 21/10/14 04:38, Arighna wrote:
> Hi Vaclav,
> the loading process.This sample data is not enough. According to the ogr GeoJSON format manual
OGRFeature object."In other words: attributes have to be members of the member properties of
the Feature object.I can get a bit further in importing your attributes by using the following
at the beginning{"type": "Feature",
"geometry":
{"type": "Point",
"properties":
"properties":
"air_temp":32.0,
etc
recognized as double precision in the attribute table.To check quickly how ogr parses the attributes, you can check on the
command
line withogrinfo point.json OGRGeoJSON
Moritz
I am trying to append points to a new map patch_map6.
v.patch -e input=patch_map1 output=patch_map6
When I run the above command I get the following error.
ERROR: Key column not found
Roy
Sent: Sunday, November 23, 2014 5:17 PM
To: Arighna
Hi Roy,
please send the question to the mailing list. I was not using v.patch with attribute table lately, so I don’t know and even if I would the question/answer might useful for other people too. Try -e flag and post also result of that (not only if it does not work but even if it works).
Vaclav
On Sun, Nov 23, 2014 at 6:11 PM, Arighna <roy.arighna@gmail.com> wrote:
Hi Vaclav,
When I patch two maps, I can see 2 points in the same map but the attribute table is not populated for the new point.
v.patch -a input=patch_map1 output=patch_map5 –overwrite
I am trying to append points to patch_map5. In the above command I can see only one row in the attribute table. Map1 attributes did not get populated.
Roy
Sent: Thursday, November 06, 2014 7:08 PM
To: Arighna
Cc: Moritz Lennert; GRASS user listSubject: Re: [GRASS-user] Loading JSON data in GRASS
for loading a new json file does not work.Import individual JSON files separately and then patch (merge) them using v.patch.
To: ‘Moritz Lennert’
Cc: grass-user@lists.osgeo.org; ‘Vaclav Petras’
Arighna
To: Arighna; ‘Vaclav Petras’
Hi Vaclav,
[1], “according to the GeoJSON Specification, only the Feature object must
OGRFeature object.”In other words: attributes have to be members of the member properties of
at the beginning{“type”: “Feature”,
“geometry”:
{“type”: “Point”,
“coordinates”: [50.922759,-90.089954] },
“properties”:
{ “unit”: “F”, “value”: 32.0 }
“properties”:
“air_temp”:32.0,
etc
recognized as double precision in the attribute table.To check quickly how ogr parses the attributes, you can check on the command
Moritz
I don't know which column it is looking for.
Roy
On 30/11/14 06:10, arighna roy wrote:
The "key column" is the column in the attribute table containing the category values (~ ids) of the features in your map, thus allowing to link the features to the attributes.
You can use 'v.db.connect -p patch_map1' to see the details of the connection for patch_map1.
Moritz
Hi Moritz,
Thanks a lot for your reply.
It is connected with the 'cat' column as I didn't provide any key column
while importing the data. Both the input and the output maps have the key
column as 'cat'. Still I am getting the error. Could this be a problem that
for both the maps the 'cat 'values are 1?
Also I was trying to import the data with a specific key column. But there
is no provision for doing that.
I tried these commands.
v.in.ogr input=/home/aroy/geojson_sample/patch/patch1.1.geojson
output=patch_test1 key=category
ERROR: Sorry, <input> is not a valid parameter
ERROR: Sorry, <key> is not a valid parameter
ERROR: Required parameter <dsn> not set:
(OGR datasource name)
v.in.ogr dsn=/home/aroy/geojson_sample/patch/patch1.1.geojson
Thanks & Regards
Roy
Sent: Tuesday, December 02, 2014 2:41 AM
To: arighna roy; Vaclav Petras; grass-user@lists.osgeo.org
Moritz
On 02/12/14 10:12, Arighna wrote:
Hi Moritz,
for both the maps the 'cat 'values are 1?Also I was trying to import the data with a specific key column. But there
I tried these commands.v.in.ogr input=/home/aroy/geojson_sample/patch/patch1.1.geojson
(OGR datasource name)v.in.ogr dsn=/home/aroy/geojson_sample/patch/patch1.1.geojson
You are using grass6.4, I suppose ? In that version v.in.ogr does not have a key parameter.
Could you send us the output of
v.db.connect -p patch_test1
and
v.info -c patch_test1
Also, I don't really understand the sens of your v.patch:
Why only one input map ? Doing that is somewhat like copying patch_map1 to patch_map6...
If patch_map6 already exists and you want to append patch_map1 to it, then you have to use the '-a' flag.
Moritz
I am using -e flag to copy the attribute table as well. I have data in json
format. I am importing json data in separate maps and then patching them
into one map to have all the points in one place. I did not find any smarter
way to import them. Is there any way that I can directly insert the records
in the db instead of saving them in json file first and then importing it?
I am using GRASS 7.0.
layer <1/patch_map1> table <patch_map1> in database
</home/shared/research/GRASSDATA/RedRiverValley/aroy/sqlite/sqlite.db>
through driver <sqlite> with key <cat>
v.info -c patch_map1
INTEGER|cat
CHARACTER|air_temp
CHARACTER|cloud_cover
CHARACTER|descriptors
CHARACTER|dew_point
CHARACTER|ice_acc_last_hour
CHARACTER|liquid_acc_last_hour
CHARACTER|msl_pressure
CHARACTER|precip_acc_last_hour
CHARACTER|relative_humidity
CHARACTER|snow_acc_last_hour
CHARACTER|station_pressure
CHARACTER|u_wind_speed
CHARACTER|v_wind_speed
DOUBLE PRECISION|valid_time_end
DOUBLE PRECISION|valid_time_start
CHARACTER|visibility
CHARACTER|wind_direction
CHARACTER|wind_speed
Displaying column types/names for database connection of layer <1>:
(Tue Dec 2 10:47:58 2014) Command finished (0 sec)
Thanks
Roy
Sent: Tuesday, December 02, 2014 3:54 AM
To: Arighna; 'Vaclav Petras'; grass-user@lists.osgeo.org
Hi Moritz,
column while importing the data. Both the input and the output maps
have the key column as 'cat'. Still I am getting the error. Could this
be a problem that for both the maps the 'cat 'values are 1?Also I was trying to import the data with a specific key column. But
there is no provision for doing that.
key parameter.
and
patch_map6...
Moritz
So, if you have several patch_map*, then you could just do:
v.patch -e in=patch_map1,patch_map2,patch_map3[,...] output=patched_map
What I don't understand is why you do
v.patch -e in=patch_map1 out=patch_map6
which doesn't patch any maps together, but just copies patch_map1 to patch_map6...
In what format are they before you save them into json format ?
If you stick with json, couldn't you just glue your json files together before importing ?
through driver <sqlite> with key <cat>v.info -c patch_map1
INTEGER|cat
CHARACTER|air_temp
CHARACTER|dew_point
(Tue Dec 2 10:47:58 2014) Command finished (0 sec)Thanks
Roy
Everything looks fine here...
Moritz
Hi Moritz,
This command has worked. Thanks a lot Moritz. This is the command('in' instead of 'input') I was looking for.
Is there any documentation where I could find these commands in detail? I did not find this in http://grass.osgeo.org/documentation/manuals/.
Thanks again
Roy
Sent: Wednesday, December 03, 2014 3:59 AM
json format. I am importing json data in separate maps and then
patching them into one map to have all the points in one place.
before importing ?
INTEGER|cat
CHARACTER|air_temp
CHARACTER|dew_point
Roy
Moritz
On 04/12/14 03:02, Arighna wrote:
Hi Moritz,
'in' is just short for 'input' and it is a parameter of the command v.patch, not a command in itself. In GRASS you can abbreviate all parameter names as long as your abbreviation is unambiguous.
v.patch -e input=patch_map1,patch_map2,patch_map3[,...] output=patched_map
should work just as well.
Moritz
Thanks again
Roy-----Original Message-----
Subject: Re: [GRASS-user] Loading JSON data in GRASSOn 02/12/14 17:51, Arighna wrote:
patching them into one map to have all the points in one place.So, if you have several patch_map*, then you could just do:
in the db instead of saving them in json file first and then importing it?In what format are they before you save them into json format ?
before importing ?I am using GRASS 7.0.
INTEGER|cat
CHARACTER|air_temp
CHARACTER|dew_point
RoyEverything looks fine here...
Moritz
