Is this 6.2.1 or 6.2.2rc1? For Ubuntu 6.2.2rc1 is strongly recommened.
GRASS 6.2.1 expects /bin/sh to point to bash, which is wrong for newer
Ubuntus, they use dash. This is fixed for 6.2.2.
I worked fine once, but later on invoking it gave following problem:
LOCATION_NAME not set.
/usr/lib/grass/etc/init.sh:573:/usr/lib/grass/etc/lock: permission
denied Unable to properly access ///.gislock
There is the problem. "///.gislock": $GISDBASE, $LOCATION_NAME, and
$MAPSET are empty.
$GISBASE/etc/Init.sh does:
LOCATION="${GISDBASE?}/${LOCATION_NAME?}/${MAPSET?}"
# Check for concurrent use
lockfile="$LOCATION/.gislock"
"$ETC/lock" "$lockfile" $$
Those are empty so LOCATION is reduced to ""/""/"" = "//" and the
lock program tries to create a lock file in the system root directory.
In my own wisdom(?) I deleted lock file and created with 777
permission. This did not solve problem.
I uninstalled GRASS6.2, and installed GRASS6.0.2 from default Ubuntu
repositories, but found it still gives lock problem.
How to get rid of this LOCKED problem.
try moving ~/.grassrc6 out of the way, or edit what's inside it if it's
wrong.
or try starting grass with
$ grass6 /path/to/mapset
another (unlikely) idea is that the g.gisenv module is broken somehow.
