[GRASS-user] Long post - Remote Sensing - Classifications
Hi community,
This semester I'm teaching an Intro Remote Sensing course using commercial
softwares. Since I'm a free spirit, my goal at the end of the semester is to
show the students that everything could be done using GRASS rather than
Envi,Erdas or Idrisi.
Given the fact that they are familiar with GUIs, I'd like to use “graphical”
commands as much as possible (I don't want to scare them)
I have a few questions:
How do I actually save a color composite image as a raster? I know how to
create it and visualize it
(GUI: Add RGB or HIS layer → I choose the bands → Display active layer on
the Map Display)
(Command: d.rgb red=lsat5_1987_40@landsat green=lsat5_1987_50@landsat
blue=lsat5_1987_30@landsat -o)
...but I don't know how to save it, say, to use it as a base image to draw
ground truth for a supervised classification.
The other question is something that has been getting me crazy for a couple
of days: classifications.
(GUI: Imagery → Develop images and groups → Create/edit group. In the
i.group window I type the name of the group, sub-group and I include rasters
in the group)
(Command: i.group group=lsat_try subgroup=lsat_try
input=lsat5_1987_10@landsat,lsat5_1987_20@landsat,lsat5_1987_30@landsat,lsat5_1987_40@landsat,lsat5_1987_50@landsat,lsat5_1987_70@landsat)
and the output is:
group [lsat_try] - does not yet exist. Creating...
Adding files to group [lsat_try]
Adding raster map [lsat5_1987_10]
Adding raster map [lsat5_1987_20]
Adding raster map [lsat5_1987_30]
Adding raster map [lsat5_1987_40]
Adding raster map [lsat5_1987_50]
Adding raster map [lsat5_1987_70]
Writing group REF
Done.
Adding files to subgroup [lsat_try]
Writing subgroup REF
Done.
So far so good..right?
Now..
(GUI: Imagery → Classify Image → Clustering input for unsupervised
classification)
In the i.cluster window I type lsat_try for the group, lsat_try for the
sub-group, lsat_sign for the signature file, say 15 classes, 50,50 for the
sampling, lsat_rep for the report.txt (the rest is by default)
(Command: i.cluster group=lsat_try subgroup=lsat_try sigfile=lsat_sign
classes=15 sample=50,50 iterations=30 convergence=98.0 separation=0.0
min_size=17 reportfile=lsat_rep.txt)
output
Reading image ...
Iteration 1: % Convergence: 80.00 (0s elapsed, 0s left)
Iteration 2: % Convergence: 100.00 (0s elapsed, 0s left)
(Pretty short output, innit?)
Now..
(GUI: Imagery → Classify Image →Maximum likelyhood classification)
I fill the boxes with the required info
(Command: i.maxlik group=lsat_try subgroup=lsat_try sigfile=lsat_sign
class=class_try reject=class_try_rej)
but my output is the following:
Can't read signature file [lsat_sign].
The thing that is literally driving me crazy is that sometimes it works (few
times) others it doesn't (I generally I get error messages saying that the
sub-group doesn't exist in the mapset).
I delete everything and I start over using only the command line:
i.group group=lsat_try sub=lsat_try
in=lsat5_1987_10,lsat5_1987_20,lsat5_1987_30,lsat5_1987_40,lsat5_1987_50,lsat5_1987_70
output:
Writing group REF
Done.
Done.
i.cluster group=lsat_try sub=lsat_try sig=lsat_sign classes=15
report=lsat_rep.txt
output
Reading image ...
Iteration 1: % Convergence: 65.36 (0s elapsed, 0s left)
Iteration 2: % Convergence: 71.92 (0s elapsed, 0s left)
Iteration 3: % Convergence: 86.67 (0s elapsed, 0s left)
Iteration 4: % Convergence: 90.74 (0s elapsed, 0s left)
Iteration 5: % Convergence: 93.32 (0s elapsed, 0s left)
Iteration 6: % Convergence: 95.15 (0s elapsed, 0s left)
Iteration 7: % Convergence: 96.00 (0s elapsed, 0s left)
Iteration 8: % Convergence: 96.29 (0s elapsed, 0s left)
Iteration 9: % Convergence: 96.70 (0s elapsed, 0s left)
Iteration 10: % Convergence: 96.31 (0s elapsed, 0s left)
Iteration 11: % Convergence: 96.70 (0s elapsed, 0s left)
Iteration 12: % Convergence: 96.68 (0s elapsed, 0s left)
Iteration 13: % Convergence: 96.75 (0s elapsed, 0s left)
Iteration 14: % Convergence: 96.84 (0s elapsed, 0s left)
Iteration 15: % Convergence: 96.98 (0s elapsed, 0s left)
Iteration 16: % Convergence: 97.27 (0s elapsed, 0s left)
Iteration 17: % Convergence: 97.54 (0s elapsed, 0s left)
Iteration 18: % Convergence: 97.68 (0s elapsed, 0s left)
Iteration 19: % Convergence: 98.01 (0s elapsed, 0s left)
(Nice output!)
i.maxlik group=lsat_try sub=lsat_try sig=lsat_sign class=lsat_class
rej=lsat_class_rej
output
i.maxlik ...
(in a fraction of a second while the graphical way – when it works – takes
kind of a minute!!)
I tried to copy the images in the user mapset and start over the GUI way but
no luck!..same error.
Is this a bug or am I “the bug” :slight_smile: ??
I know that if the command line works, you all may not “see what the problem
is”? But as I said I'd like to use the GUI.
Let's try with the Supervised using the group and sub-group that worked
before:
(GUI: Imagery → Classify image → Interactive input for supervised
classifications)
i.class window, say I want to use the NIR band to draw my truths:
lsat5_1987_40
(good)
group
lsat_try (the group that worked before)
(good)
sub (if I type list to see the available sub-groups I get: no subgruop
available in the current mapset)
the same happens if I create a group and sub in the user mapset using the
copied images.
What am I doing wrong? :,(
Every input from you all will be more than appreciate.
mitch.
View this message in context: http://n2.nabble.com/Long-post---Remote-Sensing---Classifications-tp2347807p2347807.html
I forgot:
Debian Lenny fresh installation
GRASS 6.3 fresh installation
mitch
mitch_TX wrote:
Hi community,
to show the students that everything could be done using GRASS rather than
“graphical” commands as much as possible (I don't want to scare them)
the Map Display)
couple of days: classifications.
rasters in the group)
and the output is:
Writing group REF
Done.
Done.
Now..
classification)
output
Reading image ...
Now..
(few times) others it doesn't (I generally I get error messages saying
that the sub-group doesn't exist in the mapset).
output:
Writing group REF
Done.
Done.
report=lsat_rep.txt
output
Reading image ...
(Nice output!)
rej=lsat_class_rej
output
i.maxlik ...
kind of a minute!!)
but no luck!..same error.
problem is”? But as I said I'd like to use the GUI.
before:
classifications)
lsat5_1987_40
(good)
group
(good)
copied images.
mitch.
View this message in context: http://n2.nabble.com/Long-post---Remote-Sensing---Classifications-tp2347807p2347914.html
On 18/02/09 17:17, mitch_TX wrote:
Hi community,
the Map Display)
r.composite
(Raster->Manage map colors->Create RGB)
There were issues in 6.3 with the GUI appending @MAPSET to names whereas the i.* commands couldn't deal with such names. This was corrected since (but probably after 6.3 came out). You might want to try with 6.4 (IIUC, there should be a Lenny package available in the gfoss.it repository soon).
before:
classifications)
lsat5_1987_40
(good)
group
(good)
copied images.
Can't help you on this one, but maybe same issue of file naming ?
Moritz
Thanks Moritz,
I couldn't find r.composite :working:..too much work.
As far as the 6.4, I'm looking forward to giving it a shot.
Thanks again,
mitch
Hi community,
commercial
to
“graphical”
the Map Display)
draw
r.composite
couple
problem
soon).
before:
classifications)
lsat5_1987_40
(good)
group
(good)
copied images.
Moritz
grass-user mailing list
grass-user@lists.osgeo.org
View this message in context: http://n2.nabble.com/Long-post---Remote-Sensing---Classifications-tp2347807p2348306.html
GRASS> cd $GISBASE/etc/gm/
GRASS> less gmmenu.tcl
/composite [Enter]
up up up
it's in "Raster -> Manage map colors -> Create RGB"
there was a wish a while ago to build a menu tree for the commands, not
sure if it went anywhere. Maybe something could be built into
tools/module_synopsis.sh (add a line of text under each module descr with
italicized a->b->c menu location?)
[note to self: update the synopsis PDF for 6.4.0]
crazy for a couple of days: classifications.
unsupervised classification)
output
Reading image ...
perhaps the computational region is different than the map's?
config -> region -> change region -> set region to match this raster map
Moritz:
I would say "mitigated" not "corrected". The imagery modules generally
still don't like to look at maps in @othermapsets, and generally don't
like @currentmapset tacked on map names either. But hopefully it breaks
less now and exits with an understandable error message. The imagery libs
need some TLC.
Hamish
Hi Hamish,
/composite [Enter]
up up up
it’s in “Raster → Manage map colors → Create RGB”
…thanks, Moritz told me where to find it…my bad!
perhaps the computational region is different than the map’s?
config → region → change region → set region to match this raster map
I did that but I’ll try it again (I’m not completely sure that I checked the region
while I was trying to do it via GUI – I’m sure I did it via command…in fact good output).
I would say “mitigated” not “corrected”. The imagery modules generally
still don’t like to look at maps in @othermapsets, and generally don’t
need some TLC.
Are you saying that it’s not a matter of version? Would I have the same problem
with the 6.4?
I’m sure it doesn’t work when I copy the images in the user mapset…would that work
working in PERMANENT?
I did try to include the images in the group using the graphic way but deleting (in the box) @mapset…no luck.
But still, how about the Supervised? Wouldn’t that work and tell me that THERE IS a sub-group
since I used it (the one created via command) for the Usupervised? (I tried to create another group – via command –
and run the i.class but when I have to define the subgroup…nothing!..it doesn’t find it.
mitch.
Da: Hamish (via Nabble) <ml-user+64140-560766368@…>
A: mitch_TX <reflexeos@…>
Inviato: Mercoledì 18 febbraio 2009, 20:25:52
Oggetto: Re: [GRASS-user] Long post - Remote Sensing - Classifications
I couldn’t find r.composite :working:…too much work.
/composite [Enter]
up up up
output
Reading image …
Moritz:
whereas the i.* commands couldn’t deal with such names. This was
need some TLC.
Hamish
grass-user@…
This email is a reply to your post @ http://n2.nabble.com/Long-post—Remote-Sensing—Classifications-tp2347807p2350763.html
You can reply by email or by visting the link above.
Passa a Yahoo! Mail.
La webmail che ti offre GRATIS spazio illimitato, antispam e messenger integrato.
View this message in context: Re: [GRASS-user] Long post - Remote Sensing - Classifications
[finding r.composite]
todo. hmmm...
MODULE=r.composite
xml2 < gui/wxpython/xml/menudata.xml | grep -B5000 "$MODULE" | \
   sed -e 's+^/menudata/menubar/menu/++' | tac | \
   grep '/label=\|^label=' | grep -B1000 '^label=' -m 1 | ... ?
may have to call in awk..
..thanks, Moritz told me where to find it...my bad!
if you know it's there but can't find it, what hope does a new user have
of learning that it exists? It indicates a non-intuitive placement or
where the label could be improved. This sort of feedback is rather
valuable IMO.
Hamish:
> The imagery libs need some TLC.
Are you saying that it's not a matter of version?
no. it should be better in 6.4. Just that even with the new fixes the
imagery modules (library) are still not as solid as the raster modules
in this regard.
Would I have the same problem with the 6.4?
I don't know. Hopefully it is fixed, but it might not be. (feedback
from users is really the only way to know)
I'm sure it doesn't work when I copy the images in the user mapset...
would that work working in PERMANENT?
try with the imagery maps in the same mapset. perhaps with the maps
in PERMANENT you don't need @mapset (it's in the search path), so
it would be ok. shrug.
graphic way but deleting (in the box) @mapset...no luck.
you can look in the $MAPSET/groups/ files too, they are just plain text.
But still, how about the Supervised? Wouldn't that work
Usupervised? (I tried to create another group -- via command --
subgroup...nothing!..it doesn't find it.
I don't work with any of the classification stuff, so am not really
familiar with them, but if you can recreate the problem(s) from the
command line, using the North Carolina or Spearfish sample datasets,
please post the commands to trigger it to the bug tracker and we can
try and reproduce it at our end.
Hamish
todo. hmmm...
MODULE=r.composite
valuable IMO.
mitch:
I'm generally familiar with getting to know new GIS sw and new GUIs..that
was my bad (probably not too much attention). Commercial sw give you the
possibility to save your "visualization" once loaded (menu file->save
as...and stuff like that)...d.rast doesn't. Maybe I was expecting to find
"composite" as a key word in a first level menu rather that "Create RGB" in
a second level...but again, I wasn't paying too much attention. Once you
start understanding that in the GRASS GUI you have to look for a word
related to the module, you've got it (i.*....it's got to be in that Imagery
menu somewhere, doesn't it?)
I have to be honest though, the amount of mickeys using GRASS is pretty
relevant but, giving its CL nature (virtually everything could be done just
typing), this comment doesn't really make sense (unless the direction is
really toward a usable GUI as I read in a paper somewhere).
Hamish:
in this regard.
for all of the above --
mitch:
I installed 6.4 0rc3 and the I realized that for a couple of times
unsupervised was working entering @user and using permanent as a pool. Then,
same thing (unable to find the signature file...when all the files are there
in the group!). So I entered @permanent and worked there...fine (I still
don't understand the inconsistency). I entered @user, copied the images and
it worked. BTW I used only the GUI (I was testing it) so, a bunch of double
clicks generating a bunch of @here and @there in the file naming...that
wasn't the problem (at least in my case).
mitch:
supervised...oh man, my black ship :slight_smile:
from GUI it seemed to be working the first time:
OPTION: Name of raster map to be displayed
     key: map
  format: name
required: YES
Enter the name of an existing raster file
Enter 'list' for a list of existing raster files
Hit RETURN to cancel request
lsat7_2002_40
<lsat7_2002_40>
OPTION: Name of input imagery group
     key: group
  format: name
required: YES
Enter the name of an existing group file
Enter 'list' for a list of existing group files
landsuper
<landsuper>
OPTION: Name of input imagery subgroup
     key: subgroup
  format: name
required: YES
enter option > landsuper
You have chosen:
  subgroup=landsuper
Is this correct? (y/n) [y]
OPTION: File to contain result signatures
     key: outsig
  format: name
required: YES
Enter a new output file name
land_sup_class
<land_sup_class>
OPTION: File containing input signatures (seed)
     key: insig
  format: name
required: NO
Enter the name of an existing input file
/usr/lib/grass64/etc/grass-run.sh: line 29: 9553 Segmentation fault
ERROR: i.class exited abnormally. Press <enter> to continue.
What is that "existing input file"?....I tried everything, then I left it
empty -> enter and it kicked me out.
BUT AT LEAST THIS TIME I GOT THERE.....so, I only need to figure out what
that file is, don't I?
from COMMAND...well, that wasn't good...
i.class group=landsuper sub=landsuper map=lsat7_2002_40 outsig=outsig
Run (in Xterm) and I got the following:
If you wish to resize the X monitor, do so now. Window size is
locked while interactive modules are running.
/usr/lib/grass64/etc/grass-run.sh: line 29: i.class group=landsuper
sub=landsuper map=lsat7_2002_40 outsig=outsig: command not found
ERROR: i.class group=landsuper sub=landsuper map=lsat7_2002_40 outsig=outsig
I have no clue on that one.
I hope this my report will help.
Thanks and tell me if I have to post this somewhere else.
mitch
View this message in context: http://n2.nabble.com/Long-post---Remote-Sensing---Classifications-tp2347807p2365791.html
todo. hmmm...
MODULE=r.composite
I don't know what you're trying to do, but I'm >95% certain that it
would be easier to do it in Python, probably by cannibalising
gui/wxpython/gui_modules/menudata.py.
Oh man...you guys have to excuse me...I've just started the wxpython GUI and
it looks pretty cool =)..so, forget all I posted before and let me try it.
I'll maybe solve my problems...thanks.
Sorry again,
mitch
with
todo. hmmm...
MODULE=r.composite
View this message in context: http://n2.nabble.com/Long-post---Remote-Sensing---Classifications-tp2347807p2366095.html
let me start saying that I do like the wxpython GUI...it's very nice and
usable. It really is!...so, thank you guys for all the work you've been
doing for the community!
As far as the classification:
-Unsupervised-
Command: it works either @user or @permanent.
GUI: I got stuck at the i.cluster window. How do I set the sampling interval
values? I'm not allow to use any kind of character but numbers...how do I
differentiate row and column value?
http://n2.nabble.com/file/n2369388/sampling.png sampling.png
If I leave 1 value I get this error:
ERROR: option <sample> must be provided in multiples of 2 You provided 1
items: 50
I've notice that i.group window has been changed: shouldn't “Name of imagery
sub-group” and “Name of the raster map(s) to include in group” be under the
Required tab rather than Optional? (don't get me wrong, I don't want to
criticize in a “bad” way, it's because maybe you receive a lot of feedbacks
about other parts and this module is not so used....I haven't seen so many
Remote Sensing questions lately...that's why).
-Supervised- I couldn't figure out how to make it work.
Command:
i.group group=l_sup sub=l_sup
in=lsat7_2002_10,lsat7_2002_20,lsat7_2002_30,lsat7_2002_40,lsat7_2002_50,lsat7_2002_70
Adding raster map <lsat7_2002_10@PERMANENT> to group
Adding raster map <lsat7_2002_20@PERMANENT> to group
Adding raster map <lsat7_2002_30@PERMANENT> to group
Adding raster map <lsat7_2002_40@PERMANENT> to group
Adding raster map <lsat7_2002_50@PERMANENT> to group
Adding raster map <lsat7_2002_70@PERMANENT> to group
Adding raster map <lsat7_2002_10@PERMANENT> to subgroup
Adding raster map <lsat7_2002_20@PERMANENT> to subgroup
Adding raster map <lsat7_2002_30@PERMANENT> to subgroup
Adding raster map <lsat7_2002_40@PERMANENT> to subgroup
Adding raster map <lsat7_2002_50@PERMANENT> to subgroup
Adding raster map <lsat7_2002_70@PERMANENT> to subgroup
i.group complete.
g.region -p rast=lsat7_2002_40
projection: 99 (Lambert Conformal Conic)
zone: 0
datum: nad83
ellipsoid: a=6378137 es=0.006694380022900787
north: 228513
south: 214975.5
west: 629992.5
east: 645012
nsres: 28.5
ewres: 28.5
rows: 475
cols: 527
cells: 250325
Command finished (0 sec)
i.class group=l_sup sub=l_sup map=lsat7_2002_40 outsig=outsig
...but nothing more than that. Shouldn't I be prompted to a display where I
can draw my region of interest? (I don't know, maybe I'm expecting something
that it's not supposed to be).
GUI:
Imagery → Classify image → Interactive input for supervised classification
(requires Xterm)
a blank Monitor display and a new shell appear and nothing else.
Are all of the GUI issues due to this
http://grass.osgeo.org/wiki/WxPython-based_GUI_for_GRASS#Imagery_tools
(Status: development not started yet)
mitch
View this message in context: http://n2.nabble.com/Long-post---Remote-Sensing---Classifications-tp2347807p2369388.html
sampling interval values? I'm not allow to use any kind of character
but numbers...how do I differentiate row and column value?
of 2 You provided 1
items: 50
that's a bug, it should let you give two values. --help says:
   [sample=row_interval,col_interval]
shouldn't “Name of imagery sub-group” and “Name of the raster map(s)
to include in group” be under the Required tab rather than Optional?
'group=name' is the only required option.
you can list maps in the group without adding any, so the subgroup and
input raster maps are not needed sometimes. also subgroup really is
optional.
btw (for better or worse) those required/optional groupings happen
automatically based on module requirements. I'm not really a fan of that
but others think it's a useful feature. shrug
(don't get me wrong, I don't want to criticize in a “bad” way, it's
because maybe you receive a lot of feedbacks about other parts and this
module is not so used....I haven't seen so many Remote Sensing questions
polite and researched feedback is always welcome!
once you are comfortable that an issue is really a bug, please file a
ticket, one for each issue. if just left in the mailing list it'll
more easily be forgotten in the noise.
I'm expecting something that it's not supposed to be).
for sure old xmon based interactive monitors are gone for wxPy on Windows.
not sure about what to expect from these modules, but "supervised"
says to me some sort of map interaction is required...
GUI:
(requires Xterm)
it doesn't just need an terminal window for the text based menu & data
entry, in needs an Xmonitor as well, which is unavailable in the native MS
Windows build.
else.
we need a better "sorry, won't work on MS Windows (so far)" error message
there.
perhaps better stated as "redevelopment not started in earnest yet, Some behind-the-scenes code has been prepared, but not much. Volunteers welcome!"
Hamish
2009/2/22 mitch_TX <reflexeos@yahoo.it>:
items: 50
This bug has been already fixed in r35775 (upcoming RC4).
I've notice that i.group window has been changed: shouldn't "Name of imagery
sub-group" and "Name of the raster map(s) to include in group" be under the
criticize in a "bad" way, it's because maybe you receive a lot of feedbacks
I don't think so because the 'input' is not required in general, e.g.
for `i.group -l`.
GUI:
(requires Xterm)
right, any volunteer? :wink:
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
> of 2 You provided 1
> items: 50
got it.
optional.
I see what you're saying
> GUI:
> (requires Xterm)
Windows build.
> else.
there.
Is the wxPyhton GUI supposed to be run only on Windows?
I guess not..right?
http://svn.osgeo.org/grass/grass/trunk/gui/wxpython/README
because I'm runnig this magic on Lenny :wink: (I actually got the 6.4
version from Sid repository).
I would if I could but I don't have the required knowledge (I planned to
learn a bit of Pyhton though, so maybe one of these days).
Hamish
Since I'm here I'll use the same post to ask you another thing:
is there any way in GRASS to link different map displays and have a
"brushing" (update while dragging) or even a static d.what.rast?
mitch
> > else.
Hamish:
> message there.
[better: patch the native windows build to grey those out in the menu]
oops, sorry, I thought I remembered from an earlier post you were trying
this for a Windows computer lab.
ok so from the command line 'd.mon x0' should work to open a monitor,
and you could try the steps first from the command line (keep it simple).
If all works there you can move to trying launching it from a GUI.
i.class will always want to run in an xmon + console though.
this gets i.class working for me using the sample Spearfish imagery dataset:
g.region rast=spot.comp
d.mon x0
d.rast spot.comp
# need to do following in this order to get the r,g,b bands in correct
# order in the group/$GROUP/REF file (??) I'm not really sure.
# create group
i.group gr=spotspear in=spot.ms.1,spot.ms.2,spot.ms.3
# create subgroup
i.group gr=spotspear subgr=spot.test in=spot.ms.1,spot.ms.2,spot.ms.3
# add another map for fun
i.group gr=spotspear in=spot.comp
# run it
i.class map=spot.comp group=spotspear1 subgroup=spot.test outsig=test.txt
it doesn't seem to mind that I was running it from the user1 mapset and
the images were stored in PERMANENT.
.... and then work your way though the menus. the result is a signature
file in $MAPSET/group/$GROUPNAME/subgroup/$SUBGRNAME/sig/sig.txt
I'm not sure what good results are supposed to look like.
got the 6.4 version from Sid repository).
nice, I hadn't realized it has been uploaded there yet.
I am not sure what you mean by that.
zoom in one moves both?
and have a "brushing" (update while dragging)
d.rast.edit?
maybe r.what does what you want?
Hamish
Hamish:
i.class map=spot.comp group=spotspear subgroup=spot.test outsig=test.txt
hmmm, if I try the same from gis.m in grass65 I get:
required: NO
[$GISBASE]/etc/grass-run.sh: line 29: 20596 Segmentation fault "$@"
and the xterm closes.
Ok, it's a bug: the menu item wasn't opening an xmon for you, and wasn't
disabling GRASS_RENDER_IMMEDIATE for i.class.
For the Tcl/Tk GIS.m GUI now fixed in svn, rev 36103.
cd gui/tcltk/
svn up
make
Hamish
dataset:
d.mon x0
When I do that, I get the following warning using the wxPython GUI.
http://n2.nabble.com/file/n2389455/dx0.png dx0.png
d.rast spot.comp
# create group
# create subgroup
Yes.
# run it
That's the point. Isn't supposed to be a monitor display?
"..divided into three parts. In the upper right corner you see the image. In
the lower right corner, zoomed map portions will be displayed when using the
zoom function. In the left section of the monitor, histograms for the
selected training areas for all channels will be displayed. The training
areas can be digitized...."
(Neteler, M., H. Mitasova 2008, pp. 320-321)
...right?
It's not happening to me.
Yes...
d.rast.edit?
No. They are general simple windows displaying info regarding coordinates
and Digital Number values like:
Diplay: #
R:# G:# B:#
Proj: UTM ZONE
Map: #, # meters
Lat Long: DD, DD
Moving the cursor on 2 linked displays you have the same geo-info
(you are supposed to link 2 linkable displays) but different RGB values
(generally 2 -- or more -- different bands or color composition are loaded
on different displays).
The meaning of this is allowing a visual inspection (in terms of either
different color composition or shades of gray) of the same area, supported
by a numerical info (DN -- therefore a precise representation of the
reflectance behavior of different surfaces).
I don't know if I made myself clear..I can show you a couple of screen-shots
as soon as I get to the department (it's going to be Envi and Erdas
though...I hope you guys don't mind "commercial" images on this forum :-))
In order to use r.what you are supposed to use a separate file containing
the points you are querying, right?
No, this is not exactly what I'm talking about...or better, the outcome is
but it's not the interaction that I'm looking for. I'm talking about a
pointer based like d.what.rast one.
Hamish
mitch
View this message in context: http://n2.nabble.com/Long-post---Remote-Sensing---Classifications-tp2347807p2389455.html
dataset:
d.mon x0
Hamish meant running these modules from the command line.
areas can be digitized...." (Neteler, M., H. Mitasova 2008, pp. 320-321)
Again, this is when run from the command line using the x-monitors (i.e. d.mon).
Diplay: #
R:# G:# B:#
Proj: UTM ZONE
Map: #, # meters
Lat Long: DD, DD
In the wxGUI, if you display the two raster in the same Map Display, select both of them in the layer manager and use the query tool in the Display, you get the numerical information on both maps. But you have to open another Map Display if you want to _see_ both maps.
You have the query tool in the Map Display of the GUI.
Moritz
On Wed, 2009-02-25 at 21:28 -0800, Hamish wrote:
Hamish:
required: NO
Yes, this is what I was talking about in one of my previous post while using
the wxPython GUI I get this
http://n2.nabble.com/file/n2390051/x0.png x0.png
but we already said that was under development.
cd gui/tcltk/
svn up
make
I'm sorry Hamish, could you be a bit more "for dummies" for me ? :slight_smile: I'm
still not so familiar with this. Do I have to go in the tcltk directory and
run svn up -> make? Or do I have to download something somewhere. Again, I
got the 6.4 version from Sid but now I switched back on Lenny...would that
work the same?
Besides, are you suggesting to switch back to the tcltk GUI to make it
work?..I kind of liked the wxPython one.
Hamish
mitch
View this message in context: http://n2.nabble.com/Long-post---Remote-Sensing---Classifications-tp2347807p2390051.html
>> dataset:
>> d.mon x0
d.mon).
The funny thing is that I thought I did all of the above (from
CL)...I'll try again.
> Diplay: #
> R:# G:# B:#
> Proj: UTM ZONE
> Map: #, # meters
> Lat Long: DD, DD
Moritz
I'll try this too..I gotta go now though.
cheers,
mitch
