I was preparing a some maps for a presentation and ran into a snag. I am trying to reproject raster maps from a Lat/Long to Irish national grid. I've done this before. This time I found that I had no color. I am using William Kyngesburye's GRASS 6.4.1-5. I also tried Michael Bartons GRASS 7 SVN. There are tiles already in the Project location that I reprojected before. They still have their color. It's just that these latest attempts seemed be be stripped of their color and I can just use r.color to put it back. That doesn't seem to work either.
On Mon, Feb 13, 2012 at 3:42 AM, Kurt Springs <ferret_bard@mac.com> wrote:
Hi folks,
Please also report if the map is FP or categorical and which resampling
method you used for r.proj.
The map is a digital elevation model. Interpolation is set to nearest.
Hi folks,
I tried shifting the interpolation method. Nothing worked. When I try to change the color rules, in 6.4.1 it runs the change, but doesn't add any color. When I try in 7.0 svn, it grays the apply and okay button.
Kurt
On Feb 13, 2012, at 10:58 AM, Markus Neteler wrote:
For a DEM I would avoid nearest to obtain a better (smooth) result.
