[GRASS-user] Loss of data using v.net
I’m trying to build a network in GRASS in order to find the shortest path from any settlement out of 1120 (points), to one waste treatment facility out of 27 (points). I plan to use v.net.distance which is designated to this purpose, and to define source and destination points using a column called “type”. In that column I have assigned the settlements layer with the number 5 and the treatment facilities with 1.
My problem occurs when I try to create the network using v.net; If I define nodes layer (nlayer=2) to be 2, I lose all the points and can’t find it, even by using v.extract. Otherwise (when nlayer=1) the attributes describing type are being auromatically changed to 4, which is the type attribute for roads.
Since I have 1120 I find that using from_cat instead of a SQL restriction will be too hard.
Any one has an idea why I’m losing this crucial data and how can I prevent it from happening?
Thanks in advanced,
Dor
On Wed, Jan 23, 2013 at 8:22 PM, דור פרידמן <dof1985@gmail.com> wrote:
I'm trying to build a network in GRASS in order to find the shortest path
"type". In that column I have assigned the settlements layer with the number
nodes layer (nlayer=2) to be 2, I lose all the points and can't find it,
What is the output of v.category op=report using the output of v.net?
Markus M
roads.
will be too hard.
Any one has an idea why I'm losing this crucial data and how can I prevent
it from happening?
Thanks in advanced,
Dor
grass-user mailing list
grass-user@lists.osgeo.org
using a column called "type". In that column I have assigned the
<http://v.net>; If I define nodes layer (nlayer=2) to be 2, I lose all
the points and can't find it, even by using v.extract.
What is the exact comman line for v.extract that you used ? Did you set layer=2 ?
What does v.category option=report give you on the file resulting from v.net ?
Which version of GRASS are you using ?
Otherwise (when
v.net certainly should not (and AFAIK does not) change attribute data. Actually attribute data of points connected to the network with v.net operation=connect is not kept. As mentioned in the man page you have to reconnect your points to the attribute data by hand after running v.net.
It would help if you could give a reproducible case description, including data (possibly from the NC demo dataset), so that we can see exactly what is going wrong where.
Moritz
[please keep discussions on the mailing list]
On 23/01/13 22:23, דור פרידמן wrote:
I forgot to mention that I am using GRASS 6.4.2
These is an issue with some of the v.net.* modules (incl v.net.distance) in 6.4.2: you cannot correctly input arcs in layer 1 and nodes in layer 2. You, therefore, have to use layer 1 for everything, making sure that category values of arcs and nodes do not overlap.
I would really recommend that for serious network analysis you use grass7 in which Markus Metz has not only made the interfaces of the modules more consistent, but also increased their efficiency.
Moritz
2013/1/23 Moritz Lennert <mlennert@club.worldonline.be
<mailto:mlennert@club.worldonline.be>>
        treatment
        points
        with 1.
        <http://v.net>
        lose all
    set layer=2 ?
    from v.net <http://v.net> ?
        Otherwise (when
        changed
    v.net <http://v.net> certainly should not (and AFAIK does not)
    to the network with v.net <http://v.net> operation=connect is not
    to the attribute data by hand after running v.net <http://v.net>.
    Moritz
