Hi List,
I’m having trouble importing a shapefile with v.in.ogr that has some accented characters (like não, rodoviária).
The shapefile opend fine in QGIS and I can open the dbf on libreoffice, setting the encoding to (windows-1252/winlatin 1).
I imported the shapefile and if I run v.db.select or if I open the attribute data, accented characters are messed up. However, when I try to query the layer, an error message (png attached) will show telling me to check database settings and then gives me the reason for the failure. I can then see that the queried attributes in this windows all have the accented character.
Has anyone had any luck with accented characters in v.in.ogr? I tried changing the encoding option in v.in.ogr but could not get it to work.
I’m using grass7 from OSGeo4Win. Attached is the shapefile that I’m trying to import.
Thanks
Daniel
(attachments)
pontes.7z (8.13 KB)
