[GRASS-user] Lost metadata?
Exporting a landsat tile (i.fusion.brovey'd and i.landsat.rgb'ed),
I get this error:
r.out.gdal input=007068_15m_rgbe format=GTiff output=007068_15m_rgbe.tif type=UInt16
Writing format: GTiff
Writing type: UInt16
Input file size is 15534, 14460
0Warning 1: Lost metadata writing to GeoTIFF ... too large to fit in tag.
Reading the TIFF FAQ, I get the impression that tags are strictly
standardised, so this shouldn't happen. And anyway, this is just
landsat, so whatever tags it has should be no surprise at all to
r.out.gdal.
Is there any way to find what metadata are lost?
Is there any way to avoid losing them?
Z
I get this error:
r.out.gdal.
AFAICT, any metadata which doesn't correspond to a known TIFF tag is
stored in a single tag in XML format. The error occurs if the XML
exceeds 32000 bytes. The code in question is in
GTiffDataset::WriteMetadata() in frmts/gtiff/geotiff.cpp.
If you need more details, you would probably be better off asking on
the GDAL mailing list. The issue is related to GDAL itself, rather
than anything in r.out.gdal (which just calls gdal_convert).
> I get this error:
> r.out.gdal.
In addition to that, if you use for example the ERDAS IMG format
(HFA), this message usually doesn't appear since this format
supports longer metadata.
