[GRASS-user] lots of "The application failed to initialize properly" in 6.4.0 on Windows
Hi there,
Not sure this is related – sorry if I should have started a new thread.
I have a WinGRASS-6.4.SVN daily build of last May 29 installed in “C:/Program Files” on Windows 7, and have been running a set of GRASS shell scripts no problem under this setup. Now I have installed also WinGRASS-6.4.0-1, and running the same scripts brings up some issues.
In particular, it seems that 6.4.0-1 has trouble deleting vectors via g.mremove, which also Maciek reported as problematic and that is why I replied to the present thread.
For example, a cleanup subroutine in a script includes the following command:
g.mremove -f vect=map*
that in 6.4.SVN works fine:
Removing vector <mapBloomday_Olive_11set10_Avg>
while in 6.4.0-1 doesn’t:
ATTENZIONE: Unable to delete file
‘C:\cygwin\home\andy/latlong/luigi/vector/mapBloomday_Olive_11set10_Avg/hist’
ATTENZIONE: couldn’t be removed
ATTENZIONE: <mapBloomday_Olive_11set10_Avg> nothing removed
and it fails to delete three more vectors the same way. However, rasters do get deleted.
In my %PATH%, I see no sign of GDAL.
I do have two versions of winGRASS around, but for that matter also a Cygwin version and an OSGeo4W one.
(Unrelated: is there a way to get GRASS messages 100% in English while working in an Italian locale?)
Luigi
