Hello everybody,
i am doing the tutorial from:
http://grass.itc.it/grass63/manuals/html63_user/v.lrs.create.html
and all seem fine, until I run the last command (v.lrs.create).
v.lrs.create --o busroute points=busstops out=route_lrs err=lrs_error lidcol=lid pidcol=lid rstable=route_lrs thresh=50
This is the error:
WARNING: Not enough points (0) attached to the line (cat 1), line skip.
WARNING: Not enough points (0) attached to the line (cat 16), line skip.
After that out_lines is empty and lrs_error show the whole network.
Am I missing something?
Thank you
Luca
Hi Luca,
maybe you need to run v.net on the network first, see
its man page for instructions to add missing nodes.
On Thu, Dec 06, 2007 at 06:39:56PM +0100, Luca Casagrande wrote:
Hello everybody,
This is the error:
Thank you
Luca
grass-user mailing list
grass-user@lists.osgeo.org
grass-user Info Page
Markus Neteler <neteler fbk eu> http://mpa.fbk.eu/markus/
FBK-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
New book: http://www.grassbook.org/
Hi Markus and thanks for your answer.
With v.net i have created a new node file for my network ( to be sure that node are connected to network).
Using that one as "milestone" I have 5 lines that go in the right output and 11 that go in the error one with the same warning then before.
Bye
Luca
Markus Neteler ha scritto:
Hi Luca,
Hello everybody,
This is the error:
Thank you
Luca
This is a pic of the operation:
http://img519.imageshack.us/my.php?image=grass63lrsho8.jpg
Luca
Hi Luca,
Hello everybody,
This is the error:
Thank you
Luca
Hello everybody,
This is the error:
Hi Luca,
I have tried the example (GRASS 6.3.CVS), no error messages...
View this message in context: http://www.nabble.com/LRS-and-Documentation-tf4957510.html#a14199718
Hello everybody,
This is the error:
Hi Luca,
Hi Markus,
yes was my fault..all worked fine.
Thanks
Luca
