[GRASS-user] m.eigensystem segfaults under Jaunty (beta)
Nikos:
m.eigensystem, compiled against latest grass6_dev _AND_
grass-6.4.0RC4 source code, segfaults under Ubuntu-J 64-bit
Beta.
It works fine with Ubuntu Intrepid! So, something in Jaunty
doesn't like m.eigensystem (fortran code?)!
Hamish:
> > any chance of debugging? (gdb, etc)
> > how far does it get?
perhaps you could compile into the fortran code some informative
hints, e.g. put scatter some of these before and after reading
the input values, etc:
----8<----
PRINT *,"Made it past normalizing the data"
----8<----
(you have recompiled everything from scratch since the upgrade,
right? ie you don't have any binaries trying to access library
adresses which have since changed)
Hamish
Nikos:
> Beta.
Hamish:
Hamish:
----8<----
----8<----
OK, maybe I'll try that also. Yes, everything from scratch -- not a
single binary...
...wait, there is FWTools. but this shouldn't have any influence in
grass' source code compilation, right?
Nikos
Nikos:
> Beta.
Hamish:
----8<----
----8<----
So I did. Randomely I've introduced in main.f some PRINT lines (I
changed the text -- details below).
I get an error when I try to compile:
# attempt to compile after changes
make MODULE_TOPDIR=/geo/osgeo/src/grass6_devel
Makefile:20: warning: overriding commands for target
`/geo/osgeo/src/grass6_devel/dist.x86_64-unknown-linux-gnu/bin/m.eigensystem'
/geo/osgeo/src/grass6_devel//include/Make/Module.make:15: warning:
ignoring old commands for target
Makefile:27: warning: overriding commands for target `clean'
/geo/osgeo/src/grass6_devel//include/Make/Rules.make:72: warning:
ignoring old commands for target `clean'
f77 -c -o main.o main.f
   MAIN eigen:
Error on line 43: Declaration error declaration among executables
Error on line 44: Declaration error declaration among executables
Error on line 45: Declaration error declaration among executables
/usr/bin/f77: aborting compilation
make: *** [main.o] Error 25
Probably I am not doing it right. Any help to (finally) debug this?
Nikos
svn diff
Index: main.f
--- main.f (revision 36664)
+++ main.f (working copy)
@@ -39,6 +39,7 @@
C of the eigen value (E).
C
+ PRINT *,"Starting the program..."
        DOUBLE PRECISION A(30,30),W1,W2,WR(30),WI(30),Z(30,30),FV1(30)
        DOUBLE PRECISION SUM1,SUM2
        INTEGER IV1(30),N
@@ -51,9 +52,10 @@
C PRINT *,"N=",N
C
+ PRINT *,"Before reading the matrix"
C read the matrix
        READ(5,*,END=1000) (( A(I,J),J=1,N),I=1,N)
+ PRINT *,"Read the matrix"
C
C run the real-general eigen subroutine
        CALL RG(30,N,A,WR,WI,1,Z,IV1,FV1,IERR)
@@ -72,6 +74,7 @@
        WRITE(6,100) "E",WR(I),WI(I), W1/SUM1 * 100.0
C
+ PRINT *,"Normalising the data"
C Normalize the eigenvectors before printing
        SUM2 = 0.0
        DO 6 J=1,N
@@ -113,8 +116,8 @@
    36 CONTINUE
     2 CONTINUE
+ PRINT *,"Made it past normalizing the data"
C
        CALL EXIT(0)
  1000 PRINT *,"Incomplete input file"
