Hamish:
> perhaps you could compile into the fortran code some informative
> hints, e.g. put scatter some of these before and after reading
> the input values, etc:
> ----8<----
> PRINT *,"Made it past normalizing the data"
> ----8<----
Nikos:
So I did. Randomely I've introduced in main.f some PRINT lines (I
changed the text -- details below).I get an error when I try to compile:
# attempt to compile after changes
make MODULE_TOPDIR=/geo/osgeo/src/grass6_devel
f77 -c -o main.o main.f
MAIN eigen:
Error on line 43: Declaration error declaration among
executables
/usr/bin/f77: aborting compilation
make: *** [main.o] Error 25
.... start by dealing with the first error on line 43 ...
svn diff
Index: main.f--- main.f (revision 36664)
+++ main.f (working copy)
@@ -39,6 +39,7 @@
^^^ diff starts on line 39
C of the eigen value
(E).C
+ PRINT *,"Starting the program..."
^^^ so this is line 43.
DOUBLE PRECISION
A(30,30),W1,W2,WR(30),WI(30),Z(30,30),FV1(30)
DOUBLE PRECISION SUM1,SUM2
INTEGER
IV1(30),N
I think you have to wait until after you define your variables before
you can run any commands like print. Try 'C'ommenting our that first
"Stating the program" one.
I am not sure, but I don't think you have to wait until the write device
(stdout) has been opened before using PRINT.
Hamish
