On Mon, Jul 20, 2009 at 8:16 PM, Hamish<hamish_b@yahoo.com> wrote:
FWIW & AFAIK, KML takes coordinates as wgs84 LL, and the "Google
projection" is a highly dubious beast that should be avoided if
at all possible.
Yes!
See also comment here: http://www.epsg-registry.org/export.htm?gml=urn:ogc:def:crs:EPSG::3857
"<remarks>
Uses spherical development of ellipsoidal coordinates. Relative to an
ellipsoidal development errors of up to 800 metres in position and 0.7
percent in scale may arise. It is not a recognised geodetic system:
see WGS 84 / World Mercator (CRS code 3395).
</remarks>
The error is significant for many GIS applications.
thank you for your feedback and advice. The 900913-projection is a "strange beast", indeed. But it's good that GRASS allows to communicate with communities which willfully avoid everything else.
> at all possible.
Yes!
"<remarks>
</remarks>
