[GRASS-user] Mac 6.4.1-3 Update Problems
I updated today to Mr. Kyngesburye's most recent binaries.
I updated the revised frameworks (GDAL complete 1.8, FreeType and Cairo) and then the application 6.4.1-3 (SnowLeopard) as per website.
I get the following error when launching wxpython. On start up Grass asks for mapset then provides following:
GRASS 6.4.1 > Traceback (most recent call last):
  File "/Applications/GRASS-6.4.app/Contents/MacOS/etc/wxpython/wxgui.py", line 1611, in <module>
    sys.exit(main())
  File "/Applications/GRASS-6.4.app/Contents/MacOS/etc/wxpython/wxgui.py", line 1604, in main
    app = GMApp(workspaceFile)
  File "/Applications/GRASS-6.4.app/Contents/MacOS/etc/wxpython/wxgui.py", line 1514, in __init__
    wx.App.__init__(self, False)
  File "/Users/Shared/unix/wxpython-snow/lib/python2.6/site-packages/wx-2.8-mac-unicode/wx/_core.py", line 7981, in __init__
  File "/Users/Shared/unix/wxpython-snow/lib/python2.6/site-packages/wx-2.8-mac-unicode/wx/_core.py", line 7555, in _BootstrapApp
  File "/Applications/GRASS-6.4.app/Contents/MacOS/etc/wxpython/wxgui.py", line 1528, in OnInit
    introBmp = introImage.ConvertToBitmap()
  File "/Users/Shared/unix/wxpython-snow/lib/python2.6/site-packages/wx-2.8-mac-unicode/wx/_core.py", line 3369, in ConvertToBitmap
wx._core.PyAssertionError: C++ assertion "image.Ok()" failed at ../src/mac/carbon/bitmap.cpp(1286) in wxBitmap(): invalid image
I am using most recent snow Leopard and the snow Leopard binaries.
tcltk works.
Have I missed something?
Thanks
Dave
That's been a very frustrating one. Some builds work for me (this does) and not for others, other builds don't work for me and do for others. Some all OK, some not.
But it does seem to be connected to libpng (which is in my UnixImageIO framework). I did forget to update the wxPython part of my GRASS distribution to use the new UnixImageIO, so that may be the problem for you (though you'd probably get a more fundamental error if that was the case). I'll have a new package online soon.
   sys.exit(main())
tcltk works.
Thanks
Dave
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
Earth: "Mostly harmless"
- revised entry in the HitchHiker's Guide to the Galaxy
Thank you.
I tried new build 6.4.1-4. The same error persisted.
I then installed 6.4.1-4 on a second computer at home (upgraded from 6.4.1RC1.)
This works well.
Three questions:
1) Home computer (working) shows Python 2.6.4. Problem computer shows Python 2.6.1. Is this a concern?
2) On home computer, (working) I installed NumPy from GDAL Complete framework. But start screen says:
GRASS 6.4.1 (xxxxxxx):~ > g.gui wxpython
profile.py: This module requires the NumPy module, which could not be imported. It probably is not installed (it's not part of the standard Python distribution). See the Numeric Python site (http://numpy.scipy.org) for information on downloading source or binaries.
Is this a Python version issue; Do I need to update from python.org?
3) Unrelated question. On 6.4.1RC1 the wxpython digitizing feature worked. Not so on 6.4.1-4. Is this intended or am I missing something?
Thanks again for help.
Dave
  sys.exit(main())
tcltk works.
Thanks
Dave
On Jun 2, 2011, at 9:47 PM, Dave Kent wrote:
Thank you.
I'll dig around some more. There may be something hidden in my development environment that is making it work for me and not making it into the installer. Though it does work on my clean mac.
This works well.
Three questions:
2.6.1 is the Apple-installed python. 2.6.4 can only be from python.org that you installed. 2.6.1 should work - I don't have python.org python installed, so everything is compiled from and runs (for me) on the system 2.6.1.
This would be a python.org python problem - my NumPy installer only installs into the system site-packages folder, so python.org doesn't see it. You would have to install numpy from the numpy site, they have a binary for the python.org python.
It was decided that the digitizer (and wxnviz/3D view) had too many problems yet (especially on windows), so it was disabled.
Dave
sys.exit(main())
tcltk works.
Thanks
Dave
grass-user mailing list
grass-user@lists.osgeo.org
First Pogril: Why is life like sticking your head in a bucket filled with hyena offal?
Second Pogril: I don't know. Why IS life like sticking your head in a bucket filled with hyena offal?
First Pogril: I don't know either. Wretched, isn't it?
-HitchHiker's Guide to the Galaxy
I removed all the frameworks as per instructions in the packages including all the components in GDAL complete and for good measure GSL.
Reinstalled all.
Grass 6.4.1-4 now works.
Note: When I executed
  sudo pkgutil --forget com.kyngchaos.UnixImageIO-D-framework-snow
return was:
   No receipt for 'com.kyngchaos.UnixImageIO-D-framework-snow' found at '/'.
which was different than the others where it returned for example:
  Forgot package 'org.gdal.gdal18-resources' on '/'.
Might this have been a concern?
Dave
Thank you.
This works well.
Three questions:
Dave
sys.exit(main())
tcltk works.
Thanks
Dave
Hmm, it's possible that the installer isn't completely removing old files when updating GRASS. Probably nothing to do with the frameworks, since they are all hardwired into GRASS and the bundled wxpython, and just deleting and reinstalling GRASS would have done the trick. I should make a note of that on my download page and in the readme.
No harm with the uninstall error (I misplaced the '-D' in the ID). The forgeting is just to be thorough, it doesn't delete the files, just the reference that they were installed. There is probably a lot in your system that you've deleted that has left behind installer receipts because noone tells you how to do that :wink:
Reinstalled all.
return was:
Dave
Thank you.
This works well.
Three questions:
Dave
sys.exit(main())
tcltk works.
Thanks
Dave
"Those people who most want to rule people are, ipso-facto, those least suited to do it."
- A rule of the universe, from the HitchHiker's Guide to the Galaxy
Thanks for your assurances on receipts.
I do think however that the problem was with the frameworks. I had deleted and re-installed GRASS multiple times previously without resolving the problem.
Dave
Reinstalled all.
return was:
Dave
Thank you.
This works well.
Three questions:
Dave
sys.exit(main())
tcltk works.
Thanks
Dave
