wxPython could be considered the only GUI option - there is the TclTk GUI still in GRASS 6.4, but I don't think it's kept up to date now, and it is not in GRASS 7.
Is there a reason for using your custom /opt/local Python for GRASS? I don't think the older system Python 2.6 version is a problem for the GUI.
If you are using the /opt/local Python unintentionally, probably what is happening is that it (or MacPorts) added something to your shell init (.bash_profile) to add /opt/local/bin to your PATH. GRASS then picks this up and uses the Python it finds there. You can get around this by adding a line to your .bash_profile:
export GRASS_PYTHON=/usr/bin/python2.6
On Aug 12, 2011, at 11:20 AM, wagner wrote:
Is this the only possibility to use a GUI an OS X?
Am 12.08.2011 um 18:05 schrieb William Kyngesburye:
It won't work 64bit - wxPython 2.8 (included in the GRASS package) can't be built 64bit on OS X.
On Aug 12, 2011, at 9:02 AM, wagner wrote:
Hello,
I tried to install GRASS with GUI on my Mac with Mac OS 10.6.6 (Snow Leopard) 64 Bit, but I always got the following message while starting:
arch: posix_spawnp: /opt/local/bin/pythonw2.6: Bad CPU type in executable
Am 12.08.2011 um 18:37 schrieb William Kyngesburye:
wxPython could be considered the only GUI option - there is the TclTk GUI still in GRASS 6.4, but I don’t think it’s kept up to date now, and it is not in GRASS 7.
Is there a reason for using your custom /opt/local Python for GRASS? I don’t think the older system Python 2.6 version is a problem for the GUI.
It won’t work 64bit - wxPython 2.8 (included in the GRASS package) can’t be built 64bit on OS X.
Hello,
