Hello everyone!
I use GRASS GIS 6.4.1 SVN version for my work. I keep the code in a directory inside my home directory. As I needed i.atcorr module I configured it with “with-cxx”. I used the following configure script
./configure --with-tcltk-includes=/usr/include/tcl8.5 --with-proj-share=/usr/share/proj --with-gdal=/usr/bin/gdal-config --with-cxx --enable-64bit --with-python=/usr/bin/python2.6-config
However I got one error in the make process in d.rast module. Therefore, as instructed I changed to that directory and ran make command. Now I get the following bunch of errors.
chethan@chethan-desktop:~/Applications/grass64_release/display/d.rast$ make
gcc -I/home/chethan/Applications/grass64_release/dist.x86_64-unknown-linux-gnu/include -g -O2 -DPACKAGE="“grassmods”" -I/home/chethan/Applications/grass64_release/dist.x86_64-unknown-linux-gnu/include -o OBJ.x86_64-unknown-linux-gnu/main.o -c main.c
main.c: In function ‘main’:
main.c:89: error: ‘flag_n’ undeclared (first use in this function)
main.c:89: error: (Each undeclared identifier is reported only once
main.c:89: error: for each function it appears in.)
make: *** [OBJ.x86_64-unknown-linux-gnu/main.o] Error 1
I have no clue as to why these errors arise. What should I do now?
Chethan S.
Chethan S.
Chethan S wrote:
Hello everyone!
it with "with-cxx". I used the following configure script
gcc
-g -O2 -DPACKAGE=\""grassmods"\"
Fixed in r44531, update your local copy and compile again, that should
do the trick.
Markus M
