I want to test the interesting net.analyze addons (mostly because of
v.net.distance). I've downloaded it but now not able to install it...
Following the instruction first I changed the directory to the path where
the downloaded addons are saved:
cd Documents/temp/net.analyze
Then I tried the make command:
make MODULE_TOPDIR=/Applications/GRASS-6.4.app/Contents/MacOS/
As a result I get the an error:
make: *** Makefile: Is a directory. Stop.
Does someone know what this could mean and what I'm doing wrong?
Tusend tack,
schorschli
View this message in context: http://n2.nabble.com/make-command-install-add-on-tp4764072p4764072.html
On Fri, Mar 19, 2010 at 5:29 PM, schorschli <matthiasoswald@hotmail.com> wrote:
Are you sure about this directory?
MODULE_TOPDIR should point to the GRASS installation directory which
contains bin/, lib/ and other GRASS stuff.
On Linux it compiles ok but I have no experience (nor access) to MacOSX.
Tusend tack,
schorschli
Thanks for answering.
Yes, the directory is the one containing the grass-folders (bin/, lib/ and
others).
I could solve this problem. It was not a wrong MODULE_TOPDIR path, but wrong
extensions for the makefiles.
Now I can run the make command. But this is resulting in hunderts of errors
and warning. Here is a printscreen of the first couple of lignes in the
console...
http://n2.nabble.com/file/n4776893/errors.png
http://n2.nabble.com/file/n4776893/errors.png errors.png
So maybe its better to just give it up with the addons...
View this message in context: http://n2.nabble.com/make-command-install-add-on-tp4764072p4776893.html
On Mon, Mar 22, 2010 at 10:44 AM, schorschli <matthiasoswald@hotmail.com> wrote:
others).
console...
It appears that it does not find the GRASS include files in your MacOSX
installation. As Linux user, I have no clue - maybe someone else in the list?
