[GRASS-user] make fails to find Platform.make
I am compiling GRASS 7.6 in an HPC cluster running Scientific Linux. make is failing to find the folder or file …/…/include/Make/Platform.make, I don’t recall seeing this before.
This is the configuration command:
./configure \
-prefix=/home/WUR/duque004/grass/ \
–enable-64bit --with-fftw-includes=/cm/shared/apps/fftw/openmpi/gcc/64/3.3.7/include/ \
–with-freetype-includes=/home/WUR/duque004/grass/freetypes/freetype-2.9.1/include/ \
–with-postgres=yes \
–with-netcdf --with-geos --with-blas --with-lapack
And its output:
GRASS is now configured for: x86_64-pc-linux-gnu
Source directory: /home/WUR/duque004/grass/grass-7.6.0
Build directory: /home/WUR/duque004/grass/grass-7.6.0
Installation directory: ${prefix}/grass-7.6.0
Startup script in directory:${exec_prefix}/bin
C compiler: gcc -g -O2
C++ compiler: c++ -g -O2
Building shared libraries: yes
OpenGL platform: X11
MacOSX application: no
MacOSX architectures:
MacOSX SDK:
BLAS support: yes
BZIP2 support: no
C++ support: yes
Cairo support: yes
DWG support: no
FFTW support: yes
FreeType support: yes
GDAL support: yes
GEOS support: yes
LAPACK support: yes
Large File support (LFS): yes
libLAS support: no
MySQL support: no
NetCDF support: yes
NLS support: no
ODBC support: no
OGR support: yes
OpenCL support: no
OpenGL support: yes
OpenMP support: no
PDAL support: no
PNG support: yes
POSIX thread support: no
PostgreSQL support: yes
Readline support: no
Regex support: yes
SQLite support: yes
TIFF support: yes
X11 support: yes
Zstandard support: no
using old PROJ 4 API
make then fails for about 50 modules, of all kinds. Running make individually always yields the same error:
$ cd /home/WUR/duque004/grass/grass-7.6.0/lib/gmath
$ make
…/…/include/Make/Vars.make:1: …/…/include/Make/Platform.make: No such file or directory
…/…/include/Make/Shlib.make:10: warning: overriding recipe for target `/dist./lib/grass_gmath…’
…/…/include/Make/Stlib.make:5: warning: ignoring old recipe for target `/dist./lib/grass_gmath…’
make: *** No rule to make target `…/…/include/Make/Platform.make’. Stop.
$ cd /home/WUR/duque004/grass/grass-7.6.0/lib/rst/interp_float
$ make
…/…/…/include/Make/Vars.make:1: …/…/…/include/Make/Platform.make: No such file or directory
…/…/…/include/Make/Shlib.make:10: warning: overriding recipe for target `/dist./lib/grass_interpfl…’
…/…/…/include/Make/Stlib.make:5: warning: ignoring old recipe for target `/dist./lib/grass_interpfl…’
make: *** No rule to make target `…/…/…/include/Make/Platform.make’. Stop.
$ cd /home/WUR/duque004/grass/grass-7.6.0/raster/r.sun
$ make
Any clues on what may be causing this? Thank you.
Luís
Hi Luí­s,
On Thu, Sep 19, 2019 at 11:24 AM Luí­s Moreira de Sousa <luis.de.sousa@protonmail.ch> wrote:
Please consider to switch to 7.8.
https://trac.osgeo.org/grass/wiki/Release/7.8.0-News
If you have to stick to Python 2, then this modification is needed in the source code (run in the main source code directory):
find -name ‘.py’ | xargs sed -i ‘s,#!/usr/bin/env python3,#!/usr/bin/env python2,’ && find -name '.py’ | xargs sed -i ‘s,python3,python2,’
It should be produced by the “configure” step.
Is the file present after having run “configure”?
Best,
Hi Markus,
thank you for the swift reply. I still do not have all the dependencies for GRASS 7.8 in this cluster, I’ll try that later. The Platform.make file is being created by the configure command:
$ find . -name “Platform.make”
./include/Make/Platform.make
Thank you.
Luís
Hi Luí­s,
On Thu, Sep 19, 2019 at 3:49 PM Luí­s Moreira de Sousa
Hi Markus,
thank you for the swift reply. I still do not have all the dependencies for GRASS 7.8 in this cluster, I'll try that later. The Platform.make file is being created by the configure command:
$ find . -name "Platform.make"
ok, good.
"make distclean" you had obviously done before, right?
Any unusual soft links there?
Luís
Markus Neteler, PhD
https://www.mundialis.de - free data with free software
https://grass.osgeo.org
https://courses.neteler.org/blog
Hello again,
I started the process from the beginning, running configure on a fresh source folder. I confirmed that indeed the Platform.make was present. This time make completed without errors:
GRASS GIS 7.6.0 exported compilation log
Started compilation: vr sep 20 08:58:53 CEST 2019
Errors in:
No errors detected.
Finished compilation: vr sep 20 09:07:06 CEST 2019
However, make install fails, again because the Platform.make file is missing. Interestingly, make itself is deleting the file, note the rm command below:
$ make install
/home/WUR/duque004/grass/grass-7.6.0/bin.x86_64-pc-linux-gnu/grass76
make install-check-built
make[1]: Entering directory `/home/WUR/duque004/grass/grass-7.6.0'
make[1]: Leaving directory `/home/WUR/duque004/grass/grass-7.6.0'
make install-check-parent
make install-check-writable
make install-check-prefix
make real-install
tar cBCf /home/WUR/duque004/grass/grass-7.6.0/dist.x86_64-pc-linux-gnu - . | tar xBCf /home/WUR/duque004/grass//grass-7.6.0 - 2>/dev/null
make[1]: [real-install] Error 2 (ignored)
rm /home/WUR/duque004/grass//grass-7.6.0/grass76.tmp
make /home/WUR/duque004/grass//bin/grass76
make[2]: Entering directory `/home/WUR/duque004/grass/grass-7.6.0'
sed -e 's#'@GISBASE@'#'/home/WUR/duque004/grass//grass-7.6.0'#g' \
    -e 's#'@LD_LIBRARY_PATH_VAR@'#'LD_LIBRARY_PATH'#g' \
    -e 's#'@CONFIG_PROJSHARE@'#'/usr/share/proj'#g' \
    /home/WUR/duque004/grass/grass-7.6.0/dist.x86_64-pc-linux-gnu/grass76.tmp > /home/WUR/duque004/grass//bin/grass76
chmod a+x /home/WUR/duque004/grass//bin/grass76
make[2]: Leaving directory `/home/WUR/duque004/grass/grass-7.6.0'
rm /home/WUR/duque004/grass//grass-7.6.0/etc/fontcap
make /home/WUR/duque004/grass//grass-7.6.0/etc/fontcap
sed -e 's#/home/WUR/duque004/grass/grass-7.6.0/dist.x86_64-pc-linux-gnu#/home/WUR/duque004/grass//grass-7.6.0#g' /home/WUR/duque004/grass/grass-7.6.0/dist.x86_64-pc-linux-gnu/etc/fontcap > /home/WUR/duque004/grass//grass-7.6.0/etc/fontcap
rm /home/WUR/duque004/grass//grass-7.6.0/demolocation/.grassrc76
make /home/WUR/duque004/grass//grass-7.6.0/demolocation/.grassrc76
sed -e 's#/home/WUR/duque004/grass/grass-7.6.0/dist.x86_64-pc-linux-gnu#/home/WUR/duque004/grass//grass-7.6.0#g' /home/WUR/duque004/grass/grass-7.6.0/dist.x86_64-pc-linux-gnu/demolocation/.grassrc76 > /home/WUR/duque004/grass//grass-7.6.0/demolocation/.grassrc76
rm /home/WUR/duque004/grass//grass-7.6.0/include/Make/Platform.make
make /home/WUR/duque004/grass//grass-7.6.0/include/Make/Platform.make
include/Make/Vars.make:1: include/Make/Platform.make: No such file or directory
make[2]: *** No rule to make target `include/Make/Platform.make'. Stop.
make[1]: *** [real-install] Error 2
make: *** [install] Error 2
How can I prevent make from deleting this file? I can try playing around with permissions, but that would be just a workaround.
Thank you.
Luís
On Fri, Sep 20, 2019 at 9:54 AM Luí­s Moreira de Sousa
Hello again,
Errors in:
No errors detected.
so, at this point the
/home/WUR/duque004/grass/grass-7.6.0/dist.x86_64-pc-linux-gnu/include/Make/Platform.make
is still there, right?
And then...
$ make install
make real-install
... it disappears?
I am quite surprised to see this error since the install part hasn't
been touched for years (as not needed).
History (last change in 2014):
https://github.com/OSGeo/grass/commits/releasebranch_7_6/include/Make/Install.make
Here it works smoothly:
make[1]: Leaving directory '/home/mneteler/software/grass76_git'
make manifests
make[1]: Entering directory '/home/mneteler/software/grass76_git'
make[1]: Nothing to be done for 'manifests'.
GRASS GIS 7.6.2dev 0506cda42 compilation log
Started compilation: Fri 20 Sep 2019 01:34:01 PM CEST
Errors in:
No errors detected.
Finished compilation: Fri 20 Sep 2019 01:54:41 PM CEST
13:54 $ make install
/home/mneteler/software/grass76_git/bin.x86_64-pc-linux-gnu/grass76
make real-install
mkdir -p -m 755 /home/mneteler/tmp//grass76
tar cBCf /home/mneteler/software/grass76_git/dist.x86_64-pc-linux-gnu
- . | tar xBCf /home/mneteler/tmp//grass76 - 2>/dev/null
rm /home/mneteler/tmp//grass76/grass76.tmp
make /home/mneteler/tmp//bin/grass76
make[2]: Entering directory '/home/mneteler/software/grass76_git'
sed -e 's#'@GISBASE@'#'/home/mneteler/tmp//grass76'#g' \
    /home/mneteler/software/grass76_git/dist.x86_64-pc-linux-gnu/grass76.tmp
chmod a+x /home/mneteler/tmp//bin/grass76
make[2]: Leaving directory '/home/mneteler/software/grass76_git'
rm /home/mneteler/tmp//grass76/etc/fontcap
make /home/mneteler/tmp//grass76/etc/fontcap
sed -e 's#/home/mneteler/software/grass76_git/dist.x86_64-pc-linux-gnu#/home/mneteler/tmp//grass76#g'
/home/mneteler/software/grass76_git/dist.x86_64-pc-linux-gnu/etc/fontcap
rm /home/mneteler/tmp//grass76/demolocation/.grassrc76
make /home/mneteler/tmp//grass76/demolocation/.grassrc76
/home/mneteler/software/grass76_git/dist.x86_64-pc-linux-gnu/demolocation/.grassrc76
rm /home/mneteler/tmp//grass76/include/Make/Platform.make
make /home/mneteler/tmp//grass76/include/Make/Platform.make
sed -e 's#^\(GRASS_HOME.[^=]*\).*#\1= /home/mneteler/tmp//grass76#g'
/home/mneteler/software/grass76_git/dist.x86_64-pc-linux-gnu/include/Make/Platform.make
rm /home/mneteler/tmp//grass76/include/Make/Grass.make
make /home/mneteler/tmp//grass76/include/Make/Grass.make
sed -e 's#^\(ARCH_DISTDIR.[^=]*\).*#\1= /home/mneteler/tmp//grass76#g'
-e 's#^\(ARCH_BINDIR.[^=]*\).*#\1= /home/mneteler/tmp//bin#g'
/home/mneteler/software/grass76_git/dist.x86_64-pc-linux-gnu/include/Make/Grass.make
/usr/bin/install -c config.status /home/mneteler/tmp//grass76/config.status
chmod -R a+rX /home/mneteler/tmp//grass76 2>/dev/null
Is this drive
/home/WUR/duque004/
on a network with "unusual" file systems? Just a wild guess...
Hi again Markus, thank you for following up.
In your example we can see this:
How can it work? Is the file recreated somehow after the rm command? What happens if you run only make include/Make/Platform.make?
Regarding the volume: I think it is NFS, providing the user areas in the HPC cluster.
Thanks you.
Luís
On Fri, Sep 20, 2019 at 2:21 PM Luí­s Moreira de Sousa <luis.de.sousa@protonmail.ch> wrote:
in this case “/home/mneteler/tmp//grass76” is the installation target, “make install” cleans up leftovers from a previous installation. The real Platform.make is in this example here:
to be installed to
What is you install target, defined with configure --prefix= ?
Markus M
Thanks you.
Luís
grass-user mailing list
grass-user@lists.osgeo.org
On Fri, Sep 20, 2019 at 3:08 PM Markus Metz <markus.metz.giswork@gmail.com> wrote:
to be installed to
Ah, I see. You configured with
/configure \
which will install GRASS to
but that is also your source and build directory. You need to move the grass source to somewhere else or use a different prefix
Markus M
Markus M
Thanks you.
Luís
Thank you both for your patience. The issue was indeed a wrong target path.
Cheers.
Luís
On Fri, 20 Sep 2019, Markus Metz wrote:
/configure \
/home/WUR/duque004/grass/grass-7.6.0 but that is also your source and
Specifying --prefix=/usr/local/ is a good place. Or, /usr/ depending on
where you want non-distribution executables to be found.
Rich
