[GRASS-user] make libs stops near make -C ogr
I’m trying to quickly come up to speed on Makefile protocols, so I might be a little green on this, but when I try to install the gass-addons, beginning with the make libs command:
http://grass.osgeo.org/wiki/Compile_and_Install#Addons
make -C postgres || echo /Users/hamannj/Documents/rufus/grass64_release/db/drivers/postgres >> /Users/hamannj/Documents/rufus/grass64_release/error.log
make -C ogr || echo /Users/hamannj/Documents/rufus/grass64_release/db/drivers/ogr >> /Users/hamannj/Documents/rufus/grass64_release/error.log
cp -f AUTHORS COPYING CHANGES REQUIREMENTS.html GPL.TXT /Users/hamannj/Documents/rufus/grass64_release/dist./
cp -fr --parents include /Users/hamannj/Documents/rufus/grass64_release/dist./
cp: illegal option – -
usage: cp [-R [-H | -L | -P]] [-fi | -n] [-apvX] source_file target_file
cp [-R [-H | -L | -P]] [-fi | -n] [-apvX] source_file … target_directory
make: [libs] Error 64 (ignored)
Jeff-Hamanns-MacBook-Pro:grass64_release hamannj$
I don’t know how this influences the ability to make and install addons (that seems to work fine), but not sure if this is something that needs to be reported.
$ cd grass-addons/raster/r.clim
$ make MODULE_TOPDIR=/usr/local/grass-6.4.0svn
$ sudo make MODULE_TOPDIR=/usr/local/grass-6.4.0svn install
$ grass64
GRASS 6.4.0svn (rufus):~ > r.clim -h
GRASS 6.4.0svn (rufus):~ > exit
seemed to work fine.
Jeff.
Jeff Hamann, PhD
PO Box 1421
Corvallis, Oregon 97339-1421
541-754-2457
jeff.hamann[at]forestinformatics[dot]com
http://www.forestinformatics.com
On Sun, Oct 4, 2009 at 5:33 PM, Jeff Hamann
<jeff.hamann@forestinformatics.com> wrote:
I'm trying to quickly come up to speed on Makefile protocols, so I might be
make -C ogr || echo
... I see that ARCH isn't set: "dist./" should be "dist.SOMEARCHSTUFF/".
What does
uname -a
say?
cp: illegal option -- -
cp [-R [-H | -L | -P]] [-fi | -n] [-apvX] source_file ...
target_directory
Apparently your "cp" command does not like --parents (while -p seems
to be there which should be the same).
Please change in the main Makefile all occurencies of --parents to -p
and tell us if this helps.
I don't know how this influences the ability to make and install addons
be reported.
Yes, well done. We have to understand what really happens
(I am not sure if --parents is GNU only or so, looks like that:
  http://lists.apple.com/archives/Unix-porting/2007/Jul/msg00002.html
The "install" target sometimes doesn't work properly. This needs
to be checked by a person knowing more about Makefile than
me (so, most folks here :slight_smile:
$ grass64
ok, good.
