Thanks to those who replied to my previous thread i.vpoints. I have been trying the CVS install and hit errors in the make process, I get similar errors using both 6.0-CVS and 6.1-CVS snapshots from http://grass.itc.it/faq/cvs_howto.html
cd /usr/local/src/grass61
tar xzf grass-6.1.cvs_src_snapshot_2006_06_18.tar.gz
export CVSROOT=:pserver:grass-guest@intevation.de:/home/grass/grassrepository
cvs login
cvs up -dP
cd grass-6.1.cvs_src_snapshot_2006_06_18
Makefile:22: include/Make/Platform.make: No such file or directory
Makefile:23: include/Make/Grass.make: No such file or directory
make: *** No rule to make target `include/Make/Grass.make'. Stop.
cvs login
cvs up -dP
here is the problem: don't run 'make distclean' because it will remove
the configuration again.
Just:
make
then (maybe as root):
make install
Markus Neteler <neteler itc it> http://mpa.itc.it/markus/
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
On Fri, 23 Jun 2006 14:08:15 +0200
> export
> cvs login cvs up -dP
> CFLAGS="-ggdb -march=k8 -Wall" ./configure \
> --with-tcltk-includes=/usr/include/tcl8.4 \
> --with-motif \
> --with-motif-includes=/usr/include/qt3 \
> --with-readline \
> --with-cxx \
> --with-odbc \
> --with-sqlite \
> --with-freetype \
> --with-postgres-includes=/usr/include/postgresql \
> --with-freetype-includes=/usr/include/freetype2 \
> --with-ffmpeg \
> --with-ffmpeg-includes=/usr/include/ffmpeg \
> --enable-64bit \
> --with-libs=/usr/lib64 \
> --with-ffmpeg \
> --with-tiff \
> --with-blas \
> --with-lapack \
> 2>&1 | tee config_log.txt
> make distclean
Also, don't build with blas and lapack, they are not used for anything.
Read REQUIREMENTS.html.
Motif id needed for xanim only - do you need it?
And no need to specify several of those switches explicitely - many are
turned on by default. See ./configure --help | grep "default: yes"
Maciek
CIEP?E KRAJE - CIEP?E MORZA. Szukasz atrakcyjnego wypoczynku w przyst?pnej cenie, zapoznaj si? z nasz? ofert?.
ZAPRASZAMY
