[GRASS-user] making sense of r.reclass.area
Dear GRASS list,
I'm having trouble understanding how to properly use ~r.reclass.area~. It seems to give inconsistent results. I'm using the following MWE to help me figure this out.
Several questions... such as:
Why are the units in hectare instead of m^2?
Why is -c and -d mutually exclusive for "mode=reclass" but not "mode=rmarea"?
Why does mode=rmarea appear to ignore the -d flag
Why does mode=reclass say it cannot find areas <=1 ha, but only if -c is used, and the module never seems to have trouble finding areas of 1 ha otherwise?
  -k.
grass72 -c EPSG:3413 ./Gclump.debug
# frink "1 hectare -> m^2" 10,000 m^2
g.region w=0 e=500 s=0 n=500 res=100 -p
debug() { r.out.xyz -i input=$@ | cut -d"|" -f3 | xargs -n5; }
r.mapcalc "foo = if(row() == 2 && ((col() > 1) && (col() < 4)) , 1, null())" --o
r.mapcalc "foo = if(row() == 3 && col() == 4, 1, foo)" --o
r.mapcalc "foo = if(row() == 4 && col() == 2, 1, foo)" --o
debug foo
# * 1 1 * *
# * * * 1 *
# * 1 * * *
# RMAREA
# simple run with no args
r.reclass.area input=foo output=o value=1 mode=lesser method=rmarea --o --q && debug o
r.reclass.area -c input=foo output=o value=1 mode=lesser method=rmarea --o --q && debug o
# WANT: include diagonal
r.reclass.area -d input=foo output=o value=1 mode=lesser method=rmarea --o --q && debug o
r.reclass.area -d -c input=foo output=o value=1 mode=lesser method=rmarea --o --q && debug o
# All produce the same output:
# * 1 1 * *
# RECLASS
r.reclass.area input=foo output=o value=1 mode=lesser method=reclass --o --q && debug o
# GOOD: flags areas <=1. Does not consider diagonal:
# * * * 1 *
# * 1 * * *
r.reclass.area -c input=foo output=o value=1 mode=lesser method=reclass --o --q && debug o
# ERROR: "No areas <= 1.000 hectar
r.reclass.area -d input=foo output=o value=1 mode=lesser method=reclass --o --q && debug o
# Appears to work, only areas <=1 flagged, including diagonal
# * 1 * * *
r.reclass.area -c -d input=foo output=o value=1 mode=lesser method=reclass --o --q && debug o
# ERROR: flags c and d are mutually exclusive
exit
rm -fR Gclump.debug
Dear All,
I am very sorry to convey this sad news on this list.
A dear friend and an early pioneer of the GRASS team,
David Hastings passed away in the Hospital in Colorado
on Monday 13 November as 11.25am.
David was a member of the GRASS-GIS Interagency Steering
Committee (GIASC) since 1987. I think he was a member till he passed
away, since GIASC was never formally disbanded.
Besides his several other accomplishments, David is also an author of the
Linux " GRASS HOWTO" [1].
David was diagnosed with a serious illness in May, 2016 and could
not recover.
Thanks David for your contributions to GRASS, RIP.
Venka
[1] http://www.tldp.org/HOWTO/GIS-GRASS/
Prof. Venkatesh Raghavan
Osaka City University, Japan
On Mon, Nov 13, 2017 at 11:24 AM, Ken Mankoff <mankoff@gmail.com> wrote:
Dear GRASS list,
I’m having trouble understanding how to properly use ~r.reclass.area~. It seems to give inconsistent results. I’m using the following MWE to help me figure this out.
Several questions… such as:
Most probably for historical reasons (the module comes from GRASS 4).
Why is -c and -d mutually exclusive for “mode=reclass” but not “mode=rmarea”?
A bug. They should always be mutually exclusive: either input is already clumped (-c flag), or clumps will be created from the input, considering diagonal neighbours (-d flag).
The -d flag only has an effect if clumps are created from the input. If the -c flag is set, the input is already clumped and the -d flag has no effect. This is (should be) independent of the mode.
Maybe because the input is not clumped?
HTH,
Markus M
-k.
frink “1 hectare → m^2” 10,000 m^2
r.mapcalc “foo = if(row() == 2 && ((col() > 1) && (col() < 4)) , 1, null())” --o
r.mapcalc “foo = if(row() == 3 && col() == 4, 1, foo)” --o
r.mapcalc “foo = if(row() == 4 && col() == 2, 1, foo)” --o
debug foo
* 1 1 * *
* * * 1 *
* 1 * * *
RMAREA
* 1 1 * *
RECLASS
* * * 1 *
* 1 * * *
* 1 * * *
exit
rm -fR Gclump.debug
grass-user mailing list
grass-user@lists.osgeo.org
Hi Markus,
Thanks for the reply. You're right that unclumped data was part of the problem, but even with that realization and more testing things still don't make sense. Specifically, the diagonal flag doesn't seem to work for rmarea for me, or I'm not understanding how it should work.
I've now clumped my input (and also test this telling r.reclass.area to clump the input by not using the "-c" flag). Text below appears OK in Gmail for me but is best viewed in fixed-width font.
# set up the environment
r.mapcalc "foo = if(row() == 4 && col() == 2, 2, foo)" --o
I think I've "clumped" the above, with diagonals, by assigning the 3 cells a value of 1 and the single cell a value of 2. Just to be sure, I'm manually running r.clump 2x:
r.clump input=foo output=foo_c # no diagonals
r.clump -d input=foo output=foo_cd # diagonal
debug foo
debug foo_cd # give the same result
# * 1 1 * *
# * * * 1 *
# * 2 * * *
And as expected,
debug foo_c
* 1 1 * *
* * * 2 *
* 3 * * *
OK. So r.reclass.area with foo_cd (diagonal clumped) and the -c flag should remove the small single cell, and retain the 3 cells with 1 diagonal, right?
And this should be the same behavior as if if I pass in foo (unclumped), no "-c" flag, and yes "-d" flag.
r.reclass.area -c input=foo_cd output=o value=1 mode=lesser method=rmarea --o --q && debug o
Everything I run here produces the same result, regardless of which of the three foo* rasters I pass in, or any of the three flag options (NONE, -c, or -d).
* 1 1 * *
  -k.
On Fri, Nov 17, 2017 at 1:40 PM, Ken Mankoff <mankoff@gmail.com> wrote:
Hi Markus,
Thanks for the reply. You’re right that unclumped data was part of the problem, but even with that realization and more testing things still don’t make sense. Specifically, the diagonal flag doesn’t seem to work for rmarea for me, or I’m not understanding how it should work.
OK, I understand now. With method=rmarea, r.reclass converts the raster clumps to vector areas. That single cell in your example below, that either belongs to the larger clump 1 (with -d) or forms a separate clump 2 (without -d) will always be a separate small vector area (topology or not does not matter here) and thus will always be removed independent of the 2-cell clump. The vector approach is thus not working here as expected.
Incidentally I have added a minsize option to r.clump in GRASS 7.4 which should work as expected. Try to use r.clump minsize=X (in number of cells) instead of r.reclass.area method=rmarea mode=lesser.
Markus M
I’ve now clumped my input (and also test this telling r.reclass.area to clump the input by not using the “-c” flag). Text below appears OK in Gmail for me but is best viewed in fixed-width font.
r.mapcalc “foo = if(row() == 4 && col() == 2, 2, foo)” --o
I think I’ve “clumped” the above, with diagonals, by assigning the 3 cells a value of 1 and the single cell a value of 2. Just to be sure, I’m manually running r.clump 2x:
debug foo
* 1 1 * *
* * * 1 *
* 2 * * *
And as expected,
debug foo_c
  • 1 1 * *
      • 2 *
  • 3 * * *
And this should be the same behavior as if if I pass in foo (unclumped), no “-c” flag, and yes “-d” flag.
  • 1 1 * *
-k.
Hi Markus,
Thanks for looking into this and explaining. I'll open a documentation bug on Trac.
Between this and mapcalc area() function in 7.3 I need to find a way use more cutting-edge GRASS versions than 7.2.2 even though I'm on OS X.
  -k.
