I’ve just started using GRASS and QGIS. I’m using r.mapcalculator to sum groups of partially overlapping rasterized polygons, with value 1 inside and null outside the polygons. I want each pixel in the output (sum) map to have the value of the number of polygons overlapping at that point, so I’m just summing them up (A+B+C…). The problem is that the sum is only performed where all polygons overlap: if there is a null value at one site, the resulting sum is null… Is there a way to tell GRASS to consider null values as zeroes when performing the sum? Or do I really have to transform null cells into zero-value cells in all rasters before summing them up? (It’s a lot of maps…)
I’d appreciate some help. Cheers,
Marcia
A. Márcia Barbosa
Dept. Biological Sciences, North 2.1
Imperial College at Silwood Park
Ascot, Berkshire SL5 7PY
United Kingdom
I've just started using GRASS and QGIS. I'm using
that point, so I'm just summing them up (A+B+C...). The
sum is null... Is there a way to tell GRASS to consider null
rasters before summing them up? (It's a lot of maps...)
maybe try "r.series method=sum"? (without the -n flag)
with r.mapcalc you can create something with isnull(), but it gets complicated. See the large "NULL support" section in the r.mapcalc help page for examples.
r.mapcalc
X=if(isnull(A), 0, A) + if(isnull(B), 0, B) + if(isnull(C), 0, C) ...
Hope it'll help you,
Tim
----- Original Nachricht ----
Von: "Barbosa, A. Marcia" <a.m.barbosa@imperial.ac.uk>
An: grass-user@lists.osgeo.org
Datum: 13.06.2008 12:46
Betreff: [GRASS-user] map algebra: sums including null values
I've just started using GRASS and QGIS. I'm using r.mapcalculator to sum
the value of the number of polygons overlapping at that point, so I'm just
summing them up (A+B+C...). The problem is that the sum is only performed
resulting sum is null... Is there a way to tell GRASS to consider null
I'd appreciate some help. Cheers,
Marcia
A. Márcia Barbosa
United Kingdom
