[GRASS-user] map calculator in python loop
dear all,
i’m dealing this time with r.mapcalc. I have different rasters which i grouped using g.list.
Now r_list contains all my raster. I want to multiply those rasters to another raster (called “costante”) in order to obtain a new map, that i want to call as r followed by the letter “k”
Here it is what i’ve done:
import grass.script as gscript
r_list = gscript.read_command(“g.list” , type = “rast” ).strip().split(“\n”)
c = " costante"
for r in r_list:
gscript.mapcalc ( " %s = %s * %s " % ((r+“k”) , r , c))
i get the following traceback message:
Invalid map <1>
parse error
ERROR: parse error
ERROR: An error occurred while running r.mapcalc
I don’t really know where i’m wrong!
Hi Alessandro,
actually, I have no experience and no idea of the scripting modul of grass. But I believe you need something like this:
script.core.list_strings(type, pattern=None, mapset=None, exclude=None, flag='')[source]
    List of elements as strings.
    Returns the output from running g.list, as a list of qualified names.
    Parameters:
        type (str) – element type (raster, vector, raster_3d, region, ...)
        pattern (str) – pattern string
        mapset (str) – mapset name (if not given use search path)
        exclude (str) – pattern string to exclude maps from the research
        flag (str) – pattern type: ‘r’ (basic regexp), ‘e’ (extended regexp), or ‘’ (glob pattern)
    Returns:
    list of elements
You find more here:
https://grass.osgeo.org/grass72/manuals/libpython/script.html?highlight=list_strings#script.core.list_strings
regards
Stefan
Alessandro Sebastiani <alessandro.sebastiani@uniroma1.it> hat am 12. Dezember 2018 um 12:59 geschrieben:
dear all,
i'm dealing this time with r.mapcalc. I have different rasters which i
another raster (called "costante") in order to obtain a new map, that i
want to call as r followed by the letter "k"
Here it is what i've done:
>>> r_list = gscript.read_command("g.list" , type = "rast"
).strip().split("\n")
>>> c = " costante"
>>> for r in r_list:
>>> gscript.mapcalc ( " %s = %s * %s " % ((r+"k") , r , c))
Invalid map <1>
parse error
ERROR: parse error
I don't really know where i'm wrong!
grass-user mailing list
grass-user@lists.osgeo.org
On 12/12/18 12:59, Alessandro Sebastiani wrote:
dear all,
i'm dealing this time with r.mapcalc. I have different rasters which i grouped using g.list.
Now r_list contains all my raster. I want to multiply those rasters to another raster (called "costante") in order to obtain a new map, that i want to call as r followed by the letter "k"
>>> r_list = gscript.read_command("g.list" , type = "rast" ).strip().split("\n")
>>> c = " costante"
>>> for r in r_list:
Try
" %sk = %s * %s " % (r , r , c) "
Moritz
I get the same error after trying with your suggestion! I tried to define rasters in different ways, like
c = [“costante”] ,
but nothing seems to change
Il giorno mer 12 dic 2018 alle ore 10:22 Moritz Lennert <mlennert@club.worldonline.be> ha scritto:
dear all,
c = " costante"
for r in r_list:
Try
Moritz
What do you want to do with "k" ?
Can you send what return gscript.verbose(( " %s = %s * %s ") % (r , r , c))
Frank
>> c = ["costante"] ,
Il giorno mer 12 dic 2018 alle ore 10:22 Moritz Lennert <mlennert@club.worldonline.be <mailto:mlennert@club.worldonline.be>> ha scritto:
    > dear all,
    > i'm dealing this time with r.mapcalc. I have different rasters
    which i
    > grouped using g.list.
    > Now r_list contains all my raster. I want to multiply those
    rasters to
    > another raster (called "costante") in order to obtain a new
    map, that i
    > want to call as r followed by the letter "k"
    > Here it is what i've done:
    > import grass.script as gscript
    > >>> r_list = gscript.read_command("g.list" , type = "rast"
    > ).strip().split("\n")
    > >>> c = " costante"
    > >>> for r in r_list:
    > >>> gscript.mapcalc ( " %s = %s * %s " % ((r+"k") , r , c))
    Try
    Moritz
dear all,
i found where the error was! i didn’t set the “g.list” command properly, in fact the map calculator could not find maps . However , here it is how i ran the mapcalc:
to Frank : k is just a suffix i wanted to use in order to give to the new map a name similar to the older map (r in this case)
Il giorno mer 12 dic 2018 alle ore 13:01 Frank David <frank.david@geophom.fr> ha scritto:
What do you want to do with “k” ?
Frank
c = [“costante”] ,
<mlennert@club.worldonline.be mailto:[mlennert@club.worldonline.be](mailto:mlennert@club.worldonline.be)>
dear all,
which i
rasters to
map, that i
c = " costante"
for r in r_list:
Try
Moritz
Hi Alessandro,
it would be great, if you also comunicate the actual solution, i.e. the proper "g.list"-command, or where you made the mistake. The mapcalc-call seems not to bee what caused the troubles. If someone runs into the same trouble as you, he would have the right hint immediately.
regards
Stefan
Alessandro Sebastiani <alessandro.sebastiani@uniroma1.it> hat am 13. Dezember 2018 um 09:15 geschrieben:
dear all,
i found where the error was! i didn't set the "g.list" command properly, in
ran the mapcalc:
ha scritto:
> Hi,
> c))
> Frank
> > >> c = ["costante"] ,
> > > dear all,
> > which i
> > rasters to
> > map, that i
> > > >>> c = " costante"
> > > >>> for r in r_list:
> > Try
> > Moritz
> > _______________________________________________
Hi Stefan and hi to everybody
the original “g.list” command was
r_list = gscript.read_command(“g.list” , type = “rast” ).strip().split()
i forgot to put (“\n”) as input parameter in the .split method. Howeever i wrote it while writing my script in this mail since i use it like 100 % of the time. In this way the mapcalc couldn’t find maps since my iteration variable was not the raster itself but every single letter composing its name. Next time i’ll be using copy&paste to avoid silly mistakes
regards
A.
Il giorno gio 13 dic 2018 alle ore 04:26 <st_kiefer@web.de> ha scritto:
Hi Alessandro,
it would be great, if you also comunicate the actual solution, i.e. the proper “g.list”-command, or where you made the mistake. The mapcalc-call seems not to bee what caused the troubles. If someone runs into the same trouble as you, he would have the right hint immediately.
regards
Stefan
dear all,
ran the mapcalc:
ha scritto:
c))
Frank
c = [“costante”] ,
dear all,
which i
rasters to
map, that i
c = " costante"
for r in r_list:
Try
Moritz
