[GRASS-user] map display query and layers
d.vect has an option for layer= but I don't get any consistent effect from the query tool in the map display. For example
GRASS GIS 7.0.4 > v.db.connect -p fuel
Vector map <fuel> is connected by:
layer <1/LAB> table <fuel_1> in database </home/dvrbts/grass/bryce/PERMANENT/sqlite/sqlite.db> through driver <sqlite> with key <cat>
layer <2/ARC> table <fuel_2> in database </home/dvrbts/grass/bryce/PERMANENT/sqlite/sqlite.db> through driver <sqlite> with key <cat>
says there two layers to this feature connected to a sqlite database. I'm interested in the data in layer=2, so
d.vect fuel layer=2
draws the map correctly, but when I click on polygons I get results from layer 1, not 2. And sometimes for other maps I get multiple layer results, but often not the one I want. It may depend on exactly where I click (e.g. nearest a centroid (often invisible) vs a boundary) but it seems more random to me.
GRASS 7.0.4
Linux 4.6.2-1-ARCH #1 SMP PREEMPT x86_64 GNU/Linux
Thanks, Dave
Hello Dave,
am I wrong or is your map connected to two distinct tables with the same
key (cat) ? then the behavior you describe may be related to a confusion
on the type of features holding 'cat' values. For exemple in the case of
a polygon map, you need to define which type of object handles cats
(i.e. boundaries or centroids).
Just to check, you can have a look at this wiki entry :
https://grasswiki.osgeo.org/wiki/Vector_Database_Management#GRASS_GIS_vector_management_model
Best,
Vincent.
d.vect fuel layer=2
GRASS 7.0.4
Thanks, Dave
grass-user mailing list
grass-user@lists.osgeo.org
Hi Vincent,
    I have studied the GRASS_GIS_vector_management_model page (and all the discussion leading up to that), and I think I understand the data model. What I don't understand is how the map display interacts with the data tables. So in my example case, yes, there are two tables, both with key=cat, but that's pretty typical for data imported into GRASS with v.in.ogr or v.in.e00. I have another case where I imported an ESRI GDB, and GRASS created 25 layers all with key=cat. When I do
d.vect bryceveg
it seems to draw correctly, but when I use the map query icon and mouse click it gives me results for layers 22, 23, 25, and 26 (which is not connected to a table). Even if I specify
d.vect bryceveg layer=1
when I query I still get 22, 23, 25, and 26, none of which I want.
    So undoubtedly it's possible (with significant effort) to convert this to 25 different vector features each with only one table, but that seems like a lot of work, and I would expect when I specify the layer to draw that's the layer that gets queried. If I have time, I'll dig into the code (hopefully python) driving the map query.
Thanks, Dave
On 10/01/16 01:04, Vincent Bain wrote:
Hello Dave,
Best,
Vincent.
d.vect fuel layer=2
GRASS 7.0.4
Thanks, Dave
Dave Roberts wrote
Hi Vincent,
d.vect bryceveg
Thanks, Dave
tested here with the NC sample data set
g.copy vector=firestations@PERMANENT,myfire
v.category input=myfire@user1
layer=1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25
output=myfire_manylayers option=transfer
v.db.addtable map=myfire_manylayers@user1 layer=2
v.db.addtable map=myfire_manylayers@user1 layer=25
map query:
east, north: 634259.762762, 238301.919626
myfire_manylayers@user1:
  Type: Point
  Layer: 1
  Category: 16
  Driver: sqlite
  Database: J:\gisdata\nc_spm_08_grass7\user1\sqlite\sqlite.db
  Table: myfire_manylayers
  Key_column: cat
  Attributes:
    cat: 16
    LABEL: RFD #23
    CITY: Raleigh
    MUN_COUNT: M
    PUMPERS: 1
    PUMPER_TAN: 0
    TANKER: 0
    MINI_PUMPE: 0
    RESCUE_SER: 0
    AERIAL: 0
    BRUSH: 0
    OTHERS: 0
    WATER_RESC: 0
    MUNCOID: 1
    BLDGCODE: 256
    AGENCY: RF
    STATIONID: RF23
    RECNO: 18
    CV_SID2: RF23
    CVLAG: 0
  Type: Point
  Layer: 2
  Category: 16
  Driver: sqlite
  Table: myfire_manylayers_2
  Key_column: cat
  Attributes:
    cat: 16
  Type: Point
  Layer: 3
  Category: 16
  Driver: sqlite
  Table: myfire_manylayers_3
  Key_column: cat
  Attributes:
    cat: 16
  Type: Point
  Layer: 4
  Category: 16
  Driver: sqlite
  Table: myfire_manylayers_4
  Key_column: cat
  Attributes:
    cat: 16
  Type: Point
  Layer: 5
  Category: 16
  Driver: sqlite
  Table: myfire_manylayers_5
  Key_column: cat
  Attributes:
    cat: 16
  Type: Point
  Layer: 6
  Category: 16
  Driver: sqlite
  Table: myfire_manylayers_6
  Key_column: cat
  Attributes:
    cat: 16
  Type: Point
  Layer: 7
  Category: 16
  Driver: sqlite
  Table: myfire_manylayers_7
  Key_column: cat
  Attributes:
    cat: 16
  Type: Point
  Layer: 8
  Category: 16
  Driver: sqlite
  Table: myfire_manylayers_8
  Key_column: cat
  Attributes:
    cat: 16
  Type: Point
  Layer: 9
  Category: 16
  Driver: sqlite
  Table: myfire_manylayers_9
  Key_column: cat
  Attributes:
    cat: 16
  Type: Point
  Layer: 10
  Category: 16
  Driver: sqlite
  Table: myfire_manylayers_10
  Key_column: cat
  Attributes:
    cat: 16
  Type: Point
  Layer: 11
  Category: 16
  Driver: sqlite
  Table: myfire_manylayers_11
  Key_column: cat
  Attributes:
    cat: 16
  Type: Point
  Layer: 12
  Category: 16
  Driver: sqlite
  Table: myfire_manylayers_12
  Key_column: cat
  Attributes:
    cat: 16
  Type: Point
  Layer: 13
  Category: 16
  Driver: sqlite
  Table: myfire_manylayers_13
  Key_column: cat
  Attributes:
    cat: 16
  Type: Point
  Layer: 14
  Category: 16
  Driver: sqlite
  Table: myfire_manylayers_14
  Key_column: cat
  Attributes:
    cat: 16
  Type: Point
  Layer: 15
  Category: 16
  Driver: sqlite
  Table: myfire_manylayers_15
  Key_column: cat
  Attributes:
    cat: 16
  Type: Point
  Layer: 16
  Category: 16
  Driver: sqlite
  Table: myfire_manylayers_16
  Key_column: cat
  Attributes:
    cat: 16
  Type: Point
  Layer: 17
  Category: 16
  Driver: sqlite
  Table: myfire_manylayers_17
  Key_column: cat
  Attributes:
    cat: 16
  Type: Point
  Layer: 18
  Category: 16
  Driver: sqlite
  Table: myfire_manylayers_18
  Key_column: cat
  Attributes:
    cat: 16
  Type: Point
  Layer: 19
  Category: 16
  Driver: sqlite
  Table: myfire_manylayers_19
  Key_column: cat
  Attributes:
    cat: 16
  Type: Point
  Layer: 20
  Category: 16
  Driver: sqlite
  Table: myfire_manylayers_20
  Key_column: cat
  Attributes:
    cat: 16
  Type: Point
  Layer: 21
  Category: 16
  Driver: sqlite
  Table: myfire_manylayers_21
  Key_column: cat
  Attributes:
    cat: 16
  Type: Point
  Layer: 22
  Category: 16
  Driver: sqlite
  Table: myfire_manylayers_22
  Key_column: cat
  Attributes:
    cat: 16
  Type: Point
  Layer: 23
  Category: 16
  Driver: sqlite
  Table: myfire_manylayers_23
  Key_column: cat
  Attributes:
    cat: 16
  Type: Point
  Layer: 24
  Category: 16
  Driver: sqlite
  Table: myfire_manylayers_24
  Key_column: cat
  Attributes:
    cat: 16
  Type: Point
  Layer: 25
  Category: 16
  Driver: sqlite
  Table: myfire_manylayers_25
  Key_column: cat
  Attributes:
    cat: 16
v.db.addcolumn map=myfire_manylayers@user1 layer=25 columns="xcoor double,
ycoor double"
v.to.db map=myfire_manylayers@user1 layer=25 option=coor columns=xcoor,ycoor
query_layer=25
d.vect map=myfire_manylayers@user1 layer=25
type=point,line,boundary,area,face color=255:128:128 fill_color=yellow
width=1 icon=basic/point
map query:
east, north: 635640.025007, 234049.31523
  Type: Point
  Layer: 1
  Category: 17
  Driver: sqlite
  Key_column: cat
  Attributes:
    cat: 17
    LABEL: RFD #17
    CITY: Raleigh
    MUN_COUNT: M
    PUMPERS: 1
    PUMPER_TAN: 0
    TANKER: 0
    MINI_PUMPE: 0
    RESCUE_SER: 0
    AERIAL: 0
    BRUSH: 0
    OTHERS: 0
    WATER_RESC: 0
    MUNCOID: 1
    BLDGCODE: 257
    AGENCY: RF
    STATIONID: RF17
    RECNO: 19
    CV_SID2: RF17
    CVLAG: 0
  Type: Point
  Layer: 2
  Category: 17
  Driver: sqlite
  Key_column: cat
  Attributes:
    cat: 17
  Type: Point
  Layer: 25
  Category: 17
  Driver: sqlite
  Key_column: cat
  Attributes:
    cat: 17
    xcoor: 635640.313379964
    ycoor: 234048.036434468
v.what -a map=myfire_manylayers@user1 layer=25 coordinates=635642.103403,
234048.276032 distance=10
East: 635642.103403
North: 234048.276032
Map: myfire_manylayers
Mapset: user1
Type: Point
Layer: 1
Category: 17
Driver: sqlite
Key column: cat
cat : 17
LABEL : RFD #17
CITY : Raleigh
MUN_COUNT : M
PUMPERS : 1
PUMPER_TAN : 0
TANKER : 0
MINI_PUMPE : 0
RESCUE_SER : 0
AERIAL : 0
BRUSH : 0
OTHERS : 0
WATER_RESC : 0
MUNCOID : 1
BLDGCODE : 257
AGENCY : RF
STATIONID : RF17
RECNO : 19
CV_SID2 : RF17
CVLAG : 0
Layer: 2
Category: 17
Driver: sqlite
Key column: cat
cat : 17
Layer: 3
Category: 17
Driver: sqlite
Key column: cat
cat : 17
Layer: 4
Category: 17
Driver: sqlite
Key column: cat
cat : 17
Layer: 5
Category: 17
Driver: sqlite
Key column: cat
cat : 17
Layer: 6
Category: 17
Driver: sqlite
Key column: cat
cat : 17
Layer: 7
Category: 17
Driver: sqlite
Key column: cat
cat : 17
Layer: 8
Category: 17
Driver: sqlite
Key column: cat
cat : 17
Layer: 9
Category: 17
Driver: sqlite
Key column: cat
cat : 17
Layer: 10
Category: 17
Driver: sqlite
Key column: cat
cat : 17
Layer: 11
Category: 17
Driver: sqlite
Key column: cat
cat : 17
Layer: 12
Category: 17
Driver: sqlite
Key column: cat
cat : 17
Layer: 13
Category: 17
Driver: sqlite
Key column: cat
cat : 17
Layer: 14
Category: 17
Driver: sqlite
Key column: cat
cat : 17
Layer: 15
Category: 17
Driver: sqlite
Key column: cat
cat : 17
Layer: 16
Category: 17
Driver: sqlite
Key column: cat
cat : 17
Layer: 17
Category: 17
Driver: sqlite
Key column: cat
cat : 17
Layer: 18
Category: 17
Driver: sqlite
Key column: cat
cat : 17
Layer: 19
Category: 17
Driver: sqlite
Key column: cat
cat : 17
Layer: 20
Category: 17
Driver: sqlite
Key column: cat
cat : 17
Layer: 21
Category: 17
Driver: sqlite
Key column: cat
cat : 17
Layer: 22
Category: 17
Driver: sqlite
Key column: cat
cat : 17
Layer: 23
Category: 17
Driver: sqlite
Key column: cat
cat : 17
Layer: 24
Category: 17
Driver: sqlite
Key column
: cat
cat : 17
Layer: 25
Category: 17
Driver: sqlite
Key column: cat
cat : 17
xcoor : 635640.313379964
ycoor : 234048.036434468
it seems that d.what.vect [1] reports always all data of all layers.
the same with v.what although the queried layer is specified.
so maybe a bug/enhancement ticket is needed.
[1] https://grass.osgeo.org/grass73/manuals/d.what.vect.html
[2] https://grass.osgeo.org/grass73/manuals/v.what.html
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/map-display-query-and-layers-tp5288830p5288923.html
https://trac.osgeo.org/grass/ticket/3172
I've attached a patch to v.what. Please test if this solves your problem.
Moritz
Thanks Helmut,
On 10/02/16 02:53, Helmut Kudrnovsky wrote:
{material deleted for space ...}
Just to be clear, in my case the problem was not that d.what.vect listed ALL the layers (that would have been OK although excessively verbose), but rather from click to click I might get different layers reported, and even different numbers of layers reported. Generally the one I wanted wasn't included or I would have ignored the problem.
Moritz has proposed a fix to the issue you noted, and it looks like it will likely solve my problem as well. That may take a while to find out though.
Thanks, Dave
Thanks Moritz. This looks like the solution I was looking for.
However, I have not been successful at building GRASS from source for quite a long time (just tried again and generated fatal errors in over
50 directories), so it will be a little while before I can test the patch. At a first glance, much of it appears to be the use of a TAB in python code causing indentation problems, but that is clearly a different issue than v.what behavior.
The v.what Makefile has a few environment variables to sort out before I can isolate just that program and substitute it in, so I will report on test results as soon as I am able.
Thanks, Dave
Moritz
50 directories),
I am happy to help offlist, as needed.
Dave Roberts wrote
Thanks Helmut,
though.
Thanks, Dave
grass-user@.osgeo
Are all vector geometries of your data available in all layers?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/map-display-query-and-layers-tp5288830p5288958.html
Moritz
grass-user@.osgeo
tested r69647
nice addition.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/map-display-query-and-layers-tp5288830p5288990.html
On Mon, Oct 3, 2016 at 7:12 PM, Dave Roberts <droberts@montana.edu> wrote:
Hi Markus,
    Given your kind offer I elected to try and compile GRASS again. This
time I was successful (after a few false starts). The primary problem was
python confusion, where arch linux assumes python3 as the default, and I had
not done the symbolic links correctly to redicrect to python2. After that
./configure \
   --without-freetype \
   --with-postgress \
   --with-readline
worked successfully. I'm now testing GRASS-7.0.5.
Glad you solved it! Please verify if all here is ok:
https://grasswiki.osgeo.org/wiki/Compile_and_Install#Arch_Linux
Best,
W dniu 03.10.2016 o 23:18, Markus Neteler pisze:
Hi Markus,
./configure \
   --with-postgress \
   --with-readline
Hi Dave,
My PKGBUILD may help:
https://gitlab.com/tutturu/grass7_pkgbuild/blob/master/PKGBUILD.
Advertised on https://grass.osgeo.org/download/software/linux/.
Maciek
Maciej Sieczka
http://www.sieczka.org
Markus, The material at the wiki (url below) did not work for me, but it DID provide the clues I needed to get things to work. I can't speak for other Arch linux users, but I don't have sudo configured and just su to root when necessary. So, the posted script failed when I didn't have permission to sudo ln -s. In addition, since I don't sudo, I don't quite understand the path being constructed. $HOME for someone using sudo is presumably their home directory (not root), and creating $HOME/usr/bin seems like an odd idea to me. so,
su
ln -s /usr/bin/python2.7 /usr/bin/python
ln -s /usr/bin/python2.7-config /usr/bin/python-config
exit
worked. That means that from now on python2 is the default, as opposed to python3, but I'm fine with that. Then, I don't have all the libraries required by the config command (notably liblas, maybe more), so the config command needed to be edited for me, and there were several libraries I didn't include in addition to freetype. Others may have different needs and experiences.
Again, I didn't sudo, but
make
su
make install
exit
worked of course. Finally, I now have /usr/bin/grass70 as GRASS-7.0.4
and /usr/local/bin/grass70 as GRASS-7.0.5. /usr/bin precedes /us/local/bin so I am at present entering /usr/local/bin/grass70 to start GRASS-7.0.5. I think
mv /usr/bih/grass70 /usr/bin/grass704
mv /usr/local/bin/grass70 /usr/bin/grass705
might be my solution to have both available.
Thanks, Dave
P.S. the subject on this rthread should probably have been switched to Arch linux GRASS build, but I left it alone to allow tracking
Hi Markus,
./configure \
   --with-postgress \
   --with-readline
Best,
David W. Roberts office 406-994-4548
Professor and Head FAX 406-994-3190
Department of Ecology email droberts@montana.edu
Montana State University
Bozeman, MT 59717-3460
Dear Maciek,
     Thanks you sincerely for an updated PKGBUILD. If I delete the includes for liblas and python-termcolor it builds successfully. Whether or not my previous reassignment of /usr/bin/python (see response to Markus) had any effect or whether your PKGBUILD finessed that I don't know. Like the AUR PKGBUILD your PKGBUILD generated an extraordinary number of warnings about
  dlsym(acl_get_file): /usr/lib/libfakeroot/libfakeroot.so: undefined symbol: acl_get_file
As I expected
pacman -U grass7-7.0.5-1-x86_64.pkg.tar.xz
complained about conflicts with the existing GRASS7; when I approved an overwrite it installed fine.
    At any rate, since I did not edit what.c to apply Moritz's patch none of this affects my issues with map display query or d.what.vect. I'll get back to that in a subsequent post.
Thanks, Dave
wrote:
Hi Markus,
problem was
and I had
After that
./configure \
   --with-postgress \
   --with-readline
Hi Dave,
Maciek
  >At any rate, since I did not edit what.c to apply Moritz's patch
none of this affects my issues with map display query or >d.what.vect.
Fyi
http://lists.osgeo.org/pipermail/grass-commit/2016-
October/040536.html
Anna committed the patch to trunk ; so if may be able to switch to trunk for
compiling, this v.what addition is available there without the need of
manually patching.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/map-display-query-and-layers-tp5288830p5289152.html
Thanks Helmut, Thanks Anna
I compiled the trunk version, and the map query tool now clearly behaves differently, but not how I expected
1) it shows all layers in the map query results, regardless of what layer (if any) was selected in d.vect
I.e.
d.vect map
d.vect map layer=1
v.vect map layer=2
all have identical results in map query. In addition, specifying layers that don't exist emits no warning, e.g. d.vect map layer=999
works fine, and behaves the same as any of the d.vect commands above
2) it highlights selected features in yellow, and the selected features (areas in my case) reflect layer #1, no matter what layer is requested in d.vect. I.e. d.vect map layer=2 map queries highlight layer 1.
I had been working on this with a quite complicated imported data set, so to isolate the behavior more clearly I created the data below
(file ascii.txt)
VERTI:
B 5
  0 0
  0 10
10 10
10 0
  0 0
C 1 1
  8 5
  1 1
B 5
10 0
10 10
20 10
20 0
10 0
C 1 1
18 5
   1 2
B 5
  3 3
  3 7
  7 7
  7 3
  3 3
C 1 1
  5 5
  1 2
B 5
13 3
13 7
17 7
17 3
13 3
C 1 1
15 5
  1 1
(end of file)
then
v.in.ascii input=ascii.txt output=ascii format=standard
g.region vect=ascii
v.category --overwrite option=add input=ascii output=new_ascii
     layer=2 type=centroid
# check results
v.category ascii op=report
# 1 layer, 4 centroids with cats 1 & 2
v.category new_ascii op=report
# 2 layers, L1 4 centroids with cats 1,2 L2 4 centroids cats=1,2,3,4
d.vect new_ascii layer=2
# and check results with map query tool
Thanks, Dave
Fyi
October/040536.html
manually patching.
best regards
Helmut
Please note: the patch that was applied was for v.what. At this stage, I haven't had the opportunity to look at the GUI, yet.
Could you test with v.what ?
Moritz
I.e.
d.vect map
d.vect map layer=1
v.vect map layer=2
(file ascii.txt)
VERTI:
B 5
  0 0
  0 10
10 10
10 0
  0 0
C 1 1
  8 5
  1 1
B 5
10 0
10 10
20 10
20 0
10 0
C 1 1
18 5
   1 2
B 5
  3 3
  3 7
  7 7
  7 3
  3 3
C 1 1
  5 5
  1 2
B 5
13 3
13 7
17 7
17 3
13 3
C 1 1
15 5
  1 1
(end of file)
then
g.region vect=ascii
# check results
Thanks, Dave
Fyi
October/040536.html
for
manually patching.
best regards
Helmut
grass-user@.osgeo
grass-user@.osgeo
AFAIK the map query hasn't been changed by Anna's commit.
v. what (https://grass.osgeo.org/grass73/manuals/v.what.html) has a changed
behaviour by now reckognizing the specified layer.
the same behaviour for the map query may need a separate enhancement ticket.
in the meantime would be v.what an alternative?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/map-display-query-and-layers-tp5288830p5289199.html
Dear Moritz and Helmut,
     v.what works perfectly; thanks for that. Sadly, the issue reflects my misunderstanding. I thought the map display GUI was calling v.what with coordinates extracted by the GUI from the mouse click. I have been talking about the map display query tool on wx# all along, so I apologize if I have used the wrong vocabulary to describe the problem.
     File PERMANENT/.tmp/hostname/MONITORS/wx0/cmd correctly reflects the layer request from d.vect, so it shouldn't be too difficult to get the GUI query tool to honor that, but I'm just beginning to dig into GRASS source code and I wouldn't want to tackle this yet.
Thanks, Dave
I.e.
d.vect map
d.vect map layer=1
v.vect map layer=2
material deleted to reduce the length
Fyi
October/040536.html
for
manually patching.
best regards
Helmut
grass-user@.osgeo
grass-user@.osgeo
best regards
Helmut
Thanks, Dave
It should be fairly simple to add. First it has to be changed in
library function vector_what, then in GUI. Please create a ticket for
that.
Anna
I.e.
d.vect map
d.vect map layer=1
v.vect map layer=2
Fyi
October/040536.html
for
manually patching.
best regards
Helmut
grass-user@.osgeo
grass-user@.osgeo
changed
ticket.
best regards
Helmut
