Dear list,
I am quite new in the GRASS Gis environment and I've some problems with the display of my features.
My GRASS version is the 6.2.3 on Open Suse 10.2 (64 bit). After defining the projection, importing the data (in this case a shape file) and entering the d.vect command nothing is drawn on the display. I also tried the d.mon command but no graphics are shown.
Can anybody help?
Regards
Chris
_________________________________________________________________
Express yourself instantly with MSN Messenger! Download today it's FREE!
http://messenger.msn.click-url.com/go/onm00200471ave/direct/01/
Hi Christian,
you can try to change the region settings to fit the map extend (in command
line):
g.region vect=map -p
d.erase
d.vect map
the -p parameter shows the current region settings (coordinates, resolution,
etc.)
Otto
On Wed, 6 Feb 2008 09:12:36 +0000
christian Brandt <chrisbrandt74@hotmail.com> wrote:
Dear list,
Can anybody help?
Regards
Chris
Hi Chris,
If you intend on using d.mon you should start a monitor with d.mon x0. Before
that, you should set the region extent. So doing
1) g.region vect=yourshpfile
2) d.mon x0
3) d.vect yourshpfile
should give you some results.
Same procedure should work for gis.m. Set your region first before drawing the
graphics.
Greetings
Frank
On Wednesday 06 February 2008 10:12:36 christian Brandt wrote:
Dear list,
display of my features. My GRASS version is the 6.2.3 on Open Suse 10.2
Can anybody help?
Regards
Chris
http://messenger.msn.click-url.com/go/onm00200471ave/direct/01/____________
___________________________________ grass-user mailing list
grass-user@lists.osgeo.org
