[GRASS-user] Map not found?
I'm working on the command line with the development version.
I have a vector area map called 'permit_area' in the PERMANENT mapset. When I
check using 'g.list type=vect' the map name is displayed. But, when I ask
g.proj or v.info to tell me about that map they tell me 'permit_area not
found.'
What might cause this behavior?
TIA,
Rich
Could you show the exact commands and output? Are you sure it’s not a typo?
On Tue, May 2, 2023 at 10:06 AM Rich Shepard <rshepard@appl-ecosys.com> wrote:
I’m working on the command line with the development version.
I have a vector area map called ‘permit_area’ in the PERMANENT mapset. When I
check using ‘g.list type=vect’ the map name is displayed. But, when I ask
g.proj or v.info to tell me about that map they tell me ‘permit_area not
found.’
TIA,
Rich
grass-user mailing list
grass-user@lists.osgeo.org
On Tue, 2 May 2023, Anna Petrášová wrote:
Could you show the exact commands and output? Are you sure it's not a typo?
Anna,
GRASS NSR_TaxLot/PERMANENT:~ > g.mapsets -p
Accessible mapsets:
PERMANENT
GRASS NSR_TaxLot/PERMANENT:~ > g.list type=vect
permit_area
GRASS NSR_TaxLot/PERMANENT:~ > g.proj -g georef=permit_area
ERROR 4: permit_area: No such file or directory
ERROR: Unable to read georeferenced file <permit_area> using GDAL library
GRASS NSR_TaxLot/PERMANENT:~ > v.info map=pernit_area
ERROR: Vector map <pernit_area> not found
g.list finds the vector file in the PERMANENT mapset so I expected to learn
details using g.proj and v.info.
Rich
On Tue, May 2, 2023 at 11:22 AM Rich Shepard <rshepard@appl-ecosys.com> wrote:
Anna,
Accessible mapsets:
PERMANENT
permit_area
georef doesn’t expect a GRASS map, but a georeferenced file.
it’s a typo
Rich
Rich, perhaps you want to consider asking these questions on Gitter?
https://gitter.im/grassgis/community
I think it’s better suited for these questions.
On Tue, May 2, 2023 at 11:26 AM Anna Petrášová <kratochanna@gmail.com> wrote:
Anna,
Accessible mapsets:
PERMANENT
permit_area
it’s a typo
Rich
georef doesn't expect a GRASS map, but a georeferenced file.
Anna.
My misunderstanding. Thanks.
it's a typo
Sigh. Missed it.
Thanks again,
Rich
I think it's better suited for these questions.
Anna,
Okay. I have a question about pulling from the github repo; my syntax is not
working. I'll get an account there and ask there because I didn't see the
answer in the grass wiki.
Rich
