[GRASS-user] Map scale wrong
So… i have converted my shape file to this projection: http://spatialreference.org/ref/epsg/4618/ on Qgis, and have created a new projection and mapset with this same epsg on Grass…
But when i import the shape on grass the map scale is still crazy, it says 1:6, but my area is huge and i can see all my points. On Qgis my same file has a 1:1.183.641 scale
And this is a problem because when i try to make the buffers over my points i have to use a very small distance:
g.run_command(‘v.buffer’, input=‘PocosSad@Map3’, output=‘boreholesGrassBuffer’, type=‘point’, distance=‘0.01’)
else my buffer covers the hole area.
Anyone knows how i can fix this map scale? or why is this strange?
my shape file is in attach,
Very tnks
(attachments)
PocosSad.cpg (4 Bytes)
PocosSad.dbf (42.5 KB)
PocosSad.prj (150 Bytes)
PocosSad.qpj (304 Bytes)
PocosSad.shp (2.37 KB)
PocosSad.shx (764 Bytes)
On Sun, Dec 13, 2015 at 3:09 PM, Alec Ventura <alecventura@hotmail.com> wrote:
you should probably use a projected coordinate system, not geographic coordinate system. The distance you specify in the buffer is now in degrees, that’s why it needs to be so small.
Anna
Very tnks
grass-user mailing list
grass-user@lists.osgeo.org
Hi Anna tnks for your answer,
so which EPSG code you suggest i use? UTM? and i have the location of each point on my attribute table as LAT and LONG, what happens with this information when it changes to a projected coordinate system?
Very tnks,
Alec
Date: Sun, 13 Dec 2015 15:15:07 -0500
Subject: Re: [GRASS-user] Map scale wrong
To: alecventura@hotmail.com
CC: grass-user@lists.osgeo.org
Anna
Very tnks
On Sun, Dec 13, 2015 at 3:33 PM, Alec Ventura <alecventura@hotmail.com>
UTM is probably fine, just create a new location (based on EPSG of the
appropriate UTM system) and use v.proj to reproject your vector from the
latlon location.
Very tnks,
Alec
wrote:
So... i have converted my shape file to this projection:
degrees, that's why it needs to be so small.
Anna
a new projection and mapset with this same epsg on Grass...
g.run_command('v.buffer', input='PocosSad@Map3',
output='boreholesGrassBuffer', type='point', distance='0.01')
Very tnks
