Is there a conversion for map units into meters or kilometers? I ask because I wanted to create some buffers but the values to be assigned are in map units.
Kurt
Kurt
If you do "g.proj -p" you will see a PROJ_UNITS section with a meters:
line containing the multiplier.
r.buffer has a built-in units= option to take care of this for you,
v.buffer does not (yet).
Hamish
