Hello all.
I have two rasters (SRTM_V2), one has data on the continental area,
with zero values in the ocean. The other (SRTM_30 PLUS) has values for
all region. I'd like to patch them, using r.mapcalc, like this:
if srtmv2==0 OR srtmv2==NULL, then use value from srtm30plus, else srtmv2.
I tried this in mapcalc:
test=if(A==0||isnull(A), B,A)
but it didn't work. the result was the same as test=if(A==0, B,A).
So how can I manage to get the condition for zero and null at the same
time? I mean, I can do this in a single operation, right? Or do I need
to make two operations?
cheers
Carlos Henrique Grohmann - Guano
Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
Linux User #89721 - carlos dot grohmann at gmail dot com
_________________
"Good morning, doctors. I have taken the liberty of removing Windows
95 from my hard drive."
--The winning entry in a "What were HAL's first words" contest judged
by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
out of the manual from r.mapcalc
Example: The users wants the NULL-valued cells to be treated like zeros. To add maps A and B (where B contains NULLs) to get a map C the user can use a construction like:
C=A + if(isnull(B),0,B)
Wolfgang
Carlos "Guâno" Grohmann schrieb:
Hello all.
cheers
OK, i did with:
test=if(A==0|||isnull(A), B,A)
instead of
Note the "III" operator
Carlos
Wolfgang
> Hello all.
> cheers
grassuser mailing list
grassuser@grass.itc.it
_________________
