Hey,
-------- Original-Nachricht --------
Datum: Fri, 4 Feb 2011 00:10:16 +0000
Von: Glynn Clements <glynn@gclements.plus.com>
An: grass-user@lists.osgeo.org
Betreff: Re: [GRASS-user] mapcalc problem in python script!!
Johannes Radinger wrote:
> Somehow I didn't your answer via email, I just found it at
> http://permalink.gmane.org/gmane.comp.gis.grass.user/38530For whatever reason, GMX doesn't like my IP address, and bounces my
emails. The problem is compounded by a "feature" of the mailing list
software which (by default) doesn't send messages to any subscriber
whose email address appears in the To or CC fields (on the assumption
that they'll already get a copy). You can (and probably should)
disable this feature in your preferences (via the link at the bottom
of the email).
I don't know which feature to disable?!? And I don't know why gmx is bouncing your emails...strange somehow...
> just to give you some more information on my problem:
> I am running exactly following script:> def main():
> grass.mapcalc("$upstream_shreve = ${upstream_part}+${shreve}",
> upstream_shreve = options['upstream_shreve'],
> upstream_part = options['upstream_part'],
> shreve = options['shreve'])
> return 0
> if __name__ == "__main__":
> options, flags = grass.parser()grass.parser() needs to know the valid options for the script. These
are specified by comments beginning with "#%". See any existing script
for reference.Then, you need to run the script with the appropriate command line
options. I'm assuming that isn't happening, because you should get an
error if you provide an unrecognised option (and there are no
recognised options).
I added your comments "#%" in the script (see attachment). Is it the only way to run the grass.mapcalc version in python with the grass.parser? I run my script external, directly from IDLE (without starting grass).
Has anyone wrote a python script for GRASS-Windows combination which is calling the mapcalculator and is totally outside of grass?
Just see my attached script.
cheers
johannes
grass-user mailing list
GMX DSL Doppel-Flat ab 19,99 Euro/mtl.! Jetzt mit
gratis Handy-Flat! http://portal.gmx.net/de/go/dsl
(attachments)
test3.py (1.55 KB)
