On Wed, Oct 15, 2014 at 6:30 PM, Frederico Mestre <
mestre.frederico@gmail.com> wrote:
Hello all:
I'm using grass through R, however I came across an error, while using a
function that uses mapcalculator:
Error in system(cmd0, intern = TRUE) : 'r.mapcalculator.exe' not found
Error in parseGRASS(cmd, legacyExec = legacyExec) :
r.mapcalculator not found
The right module for raster algebra is r.mapcalc.
r.mapcalculator is a sh script used by QGIS Processing and similar tools to
help with passing raster maps to GRASS and back. spgrass6 is not doing
anything like this as far as I know, so the standard r.mapcalc is the
module to use.
Perhaps the names are little confusing. Also the fact that r.mapcalculator
is sh script in GRASS GIS 7 is quite surprising.
