[GRASS-user] Mapping Africa in an equal area projection
Dear friends,
I would like to use it to map distribution of some specimen at a resolution of
100 km x 100 km (or even down to 25 km x 25 km).
I gathered some information, and ended up with:
1) Sinusoidal
2) Equatorial Lambert Azimuthal Equal Area
3) Albers Equal Area (Conic)
4) Mollweide
5) Cylindrical Equal Area
I do not really know which one to choose. What do you recommend?
For each of them, which ellipsoid and datum would you choose?
Regards
Corrado Topi
Global Climate Change & Biodiversity Indicators
Area 18,Department of Biology
University of York, York, YO10 5YW, UK
Phone: + 44 (0) 1904 328645, E-mail: ct529@york.ac.uk
at a resolution of 100 km x 100 km (or even down to 25 km x 25 km).
1) Sinusoidal
4) Mollweide
recommend?
I would suggest to ask on the PROJ.4 mailing list. http://proj.osgeo.org
if you are creating something custom probably stick with WGS84.
as for your point data, you can import it into a lat/lon WGS84 location
(epsg:4326) as points with v.in.ascii. once you have set up your new
projection you can pull that file over with v.proj. r.in.xyz wants a
text file as input, so you'd have to re-export (with projected coords
this time) with v.out.ascii.db (from wiki addons) or v.out.ascii + a
little cut & paste in a spreadsheet.
alternatively you can reproject your text file from lat/lon WGS84 to
(whatever) with the 'm.proj -i' module from within the new projection,
or cs2cs from proj4.
if using v.in.ascii to create a points map some stuff to play with is
v.kernel and v.surf.rst.
Hamish
