I want to develop a mapping application using python for avalanche flow simulation which takes a lot of user inputs. I do not want to go through wxGUI as the user is not interested in options shown by its GUI. Is there any documentation about 2d/3d mapping interface classes/modules which I can use. If these are not documented I can help in it.
Please take a look at the WPS option in GRASS GIS 7:
It is close to what I was trying to do but still I would love someday GRASS to have a modular GUI especially 3D which can be embedded in any app within few minutes.
Not sure I understand exactly what you are looking for, but have you looked at the toolboxes concept [1] for customizing the GRASS GUI ?
Or are you looking for a separate GUI just for the 3D viewer (wxnviz) ?
On Tue, Dec 2, 2014 at 5:25 AM, shashank khare <skhare@hotmail.com> wrote:
Thanks Markus!
few minutes.
I see, so I misunderstood your initial request. If wxPython is in
general ok for you, check also
> Thanks Markus!
within
> few minutes.
There is some basic documentation for wxGUI API, you can get it by
executing
make sphinxdoc
in GRASS source code. Then open a file
docs/html/wxgui/index.html
in the distribution (dist...) directory.
You will find there also the programmer's documentation of toolboxes
mentined by Moritz. But note that this API can change any time. You are
welcome to use it and even contribute back some improvements. Look also at
source code for g.gui.iclass and g.gui.vdigit. Let us know how it goes.
