[GRASS-user] MAPSET PERMANENT - permission denied
Hi!
On Compilation of Code ,I am getting this Error .
Thanks & Regards
Kunal Malik
09871147561
are you working in GRASS as the same user, as you were before, when you
created this location?
what does
ls -lh $GRASSDATA/$LOCATION_NAME/
say?
what does
whoami
say?
jachym
Kunal Malik píše v Út 26. 02. 2008 v 18:31 +0530:
Hi!
Thanks & Regards
Kunal Malik
09871147561
grass-user mailing list
grass-user@lists.osgeo.org
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
whoam i gives root
ls -lh $GRASSDATA/$LOCATION_NAME/ gives the output,
total 3.1M
drwxr-xr-x 2 root root 4.0K Jan 30 04:09 bin
drwxr-xr-x 3 root root 4.0K Jan 21 13:15 boot
drwxr-xr-x 8 root root 4.7K Feb 26 10:29 dev
drwxr-xr-x 86 root root 12K Feb 26 10:29 etc
drwxr-xr-x 6 root root 4.0K Feb 12 12:34 home
drwxr-xr-x 2 root root 4.0K Aug 12 2004 initrd
drwxrwxrwx 13 1000 1000 4.0K Jan 30 01:30 lame-3.96
-rwxr-xr-x 1 root root 1.2M Jan 30 01:28 lame-3.96.tar.gz
drwxr-xr-x 11 root root 4.0K Jan 22 11:57 lib
drwxrwsrwx 9 1000 1000 4.0K Jan 30 01:30 libogg-1.1.3
-rwxr-xr-x 1 root root 395K Jan 30 01:28 libogg-1.1.3.tar.gz
drwxrwsrwx 11 1000 1000 4.0K Jan 30 01:28 libvorbis-1.1.2
-rwxr-xr-x 1 root root 1.3M Jan 30 01:27 libvorbis-1.1.2.tar.gz
drwx------ 2 root root 16K Jan 21 18:41 lost+found
drwxr-xr-x 2 root root 4.0K Feb 25 17:39 media
drwxr-xr-x 2 root root 4.0K Aug 24 2005 misc
drwxr-xr-x 2 root root 4.0K Aug 12 2004 mnt
drwxr-xr-x 3 root root 4.0K Feb 20 16:28 opt
dr-xr-xr-x 124 root root 0 Feb 26 15:59 proc
drwxr-x— 30 root root 4.0K Feb 26 18:37 root
drwxr-xr-x 2 root root 12K Jan 30 04:12 sbin
drwxr-xr-x 1 root root 0 Feb 26 15:59 selinux
drwxr-xr-x 2 root root 4.0K Aug 12 2004 srv
drwxr-xr-x 9 root root 0 Feb 26 15:59 sys
drwxrwxrwt 79 root root 4.0K Feb 26 18:47 tmp
drwxr-xr-x 14 root root 4.0K Jan 21 13:15 usr
drwxr-xr-x 23 root root 4.0K Jan 21 14:24 var
what does
say?
what does
whoami
say?
jachym
Hi!
Thanks & Regards
Kunal Malik
09871147561
Jachym Cepicky
Thanks & Regards
Kunal Malik
09871147561
sorry,
$GRASSDATA should be the directory, where your GRASS data are located
$LOCATION_NAME should be name of the location, you are using for
current GRASS session
jachym
Kunal Malik píše v Út 26. 02. 2008 v 18:53 +0530:
whoam i gives root
total 3.1M
drwxr-x--- 30 root root 4.0K Feb 26 18:37 root
        when you
        what does
        say?
        what does
        whoami
        say?
        jachym
        > Hi!
        > On Compilation of Code ,I am getting this Error .
        > MAPSET PERMANENT - permission denied
        > Thanks & Regards
        > Kunal Malik
        > 09871147561
        > grass-user mailing list
        > grass-user@lists.osgeo.org
        > http://lists.osgeo.org/mailman/listinfo/grass-user
        Jachym Cepicky
Thanks & Regards
Kunal Malik
09871147561
Jachym Cepicky
Jachym Cepicky wrote:
sorry,
FWIW, the name of the GRASS variable for the database directory is
GISDBASE.
You can make the GRASS variables appear as shell variable with the
command:
  eval `g.gisenv`
After which, you can use the variables like e.g.:
  ls -l $GISDBASE/$LOCATION_NAME
or:
  ls -l $GISDBASE/$LOCATION_NAME/$MAPSET
etc.
As for the error message in the subject: you must own the mapset
directory in order to select it as the current mapset. The PERMANENT
mapset will normally be owned by whoever originally created the
location.
You shouldn't use the PERMANENT mapset as the current mapset for daily
use; create a new mapset instead. PERMANENT should be reserved for
important data which should be readily available regardless of the
current mapset.
Until you get to the point of needing several mapsets in one location,
you probably shouldn't have anything in the PERMANENT mapset except
for the standard files (DEFAULT_WIND, PROJ_INFO, PROJ_UNITS).
Hi!!
I have set the Enviroment Variable by eval ‘g.gisenv’
when i make echo $LOCATION_NAME it gives Map1
echo $MAPSET GIVES kunal
echo $GISDBASE =/usr/local/grassdata
i have following queries
i have copied the r.example dir into the /usr/local/grass-6.2.3/raster/ and add the r.example in the Make file present in this directory…when i make the directory it still giving the message
ERROR: MAPSET PERMANENT - permission denied
why is it so when i am using kunal as a mapset.
i want to see the output of r.example which i added …
i will run make install after make…my grass is also running …where to go to check the output.
Please suggest the way to handle the two problems.
Thanks
On 2/27/08, Kunal Malik <kunal.malik81@gmail.com> wrote:
Thanks Glynn for your support.
sorry,
GISDBASE.
command:
eval g.gisenv
or:
etc.
location.
You shouldn’t use the PERMANENT mapset as the current mapset for daily
current mapset.
you probably shouldn’t have anything in the PERMANENT mapset except
Thanks & Regards
Kunal Malik
09871147561
Thanks & Regards
Kunal Malik
09871147561
Hi!!
Thank
Hi!!
Thanks
sorry,
GISDBASE.
command:
eval g.gisenv
or:
etc.
location.
current mapset.
Thanks & Regards
Kunal Malik
09871147561
Thanks & Regards
Kunal Malik
09871147561
Thanks & Regards
Kunal Malik
09871147561
so,
since I do not understand, what you are doing, I'll try to describe the
"development procedure" from the beginning:
1) download the source code
2) go to grass_trunk directory
3) download r.example and unpack to grass_trunk/raster directory
4) ./configure ... ; make; sudo make install
5) go to grass_trunk/raster/r.example directory
6) You'll have to adjust MODULE_TOPDIR variable in Makefile to "../.."
7) run make
8) go to grass_trunk
9) run sudo make install
10) start grass
11) r.example should be there (r.example --help is your friend)
BTW: Maybe we should move [rv].example from intevation server to osgeo
as well ?
Where to store it? grass_source/grass-examples ?
Jachym
Kunal Malik píše v St 27. 02. 2008 v 10:51 +0530:
Hi!!
I have set the Enviroment Variable by eval 'g.gisenv'
1.
file present in this directory...when i make the directory it still
giving the message
2.
i want to see the output of r.example which i added ..
i will run make install after make..my grass is also running ..where
Thanks
                > sorry,
                > $GRASSDATA should be the directory, where your GRASS
                data are located
                > $LOCATION_NAME should be name of the location, you
                are using for
                > current GRASS session
                directory is
                GISDBASE.
                variable with the
                command:
                        eval `g.gisenv`
                or:
                etc.
                the mapset
                The PERMANENT
                created the
                location.
                mapset for daily
                reserved for
                regardless of the
                current mapset.
                in one location,
                mapset except
                PROJ_UNITS).
        Thanks & Regards
        Kunal Malik
        09871147561
Thanks & Regards
Kunal Malik
09871147561
Jachym Cepicky
osgeo as well ?
they are already in the main source, in doc/:
http://trac.osgeo.org/grass/browser/grass/trunk/doc/vector/v.example
http://trac.osgeo.org/grass/browser/grass/trunk/doc/raster/r.example
where is the old URL pointing to intevation? we could change that..
Hamish
      ____________________________________________________________________________________
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
Fixed in http://grass.osgeo.org/devel/index.php,
however, http://grass.osgeo.org/devel/cvs.php has to be rewritten
completely. But for this task is my English really ppor
jachym
Hamish píše v Út 26. 02. 2008 v 23:37 -0800:
> osgeo as well ?
Hamish
Jachym Cepicky
Hi jachym,
do i need subversion tool for downloading the source code .???
OR
i have taken grass-6.2.3.tar.gz. is it will do the same that u mentioned in the previous mail?
But it does not have grass_trunk directory …but it has the raster dir in it…
could i do the same things on grass-6.2.3 and adding r.example to raster directory,
On 2/27/08, Jachym Cepicky <jachym.cepicky@gmail.com> wrote:
so,
since I do not understand, what you are doing, I’ll try to describe the
“development procedure” from the beginning:
  1. download the source code
  2. go to grass_trunk directory
  3. download r.example and unpack to grass_trunk/raster directory
  4. ./configure … ; make; sudo make install
  5. go to grass_trunk/raster/r.example directory
  6. You’ll have to adjust MODULE_TOPDIR variable in Makefile to “…/…”
  7. run make
  8. go to grass_trunk
  9. run sudo make install
  10. start grass
  11. r.example should be there (r.example --help is your friend)
as well ?
Jachym
Hi!!
giving the message
Thanks
sorry,
data are located
are using for
directory is
GISDBASE.
variable with the
command:
eval g.gisenv
or:
etc.
the mapset
The PERMANENT
created the
location.
mapset for daily
reserved for
regardless of the
current mapset.
in one location,
mapset except
PROJ_UNITS).
Thanks & Regards
Kunal Malik
09871147561
Thanks & Regards
Kunal Malik
09871147561
Jachym Cepicky
Thanks & Regards
Kunal Malik
09871147561
Hi jachym,
OR
Does it will do the same that u mentioned in the previous mail?
when i tried this & run grass …where could i see the effect of r.example added…??
it is taken from
Hi jachym,
OR
so,
  7. run make
  10. start grass
as well ?
Jachym
Hi!!
giving the message
Thanks
sorry,
data are located
are using for
directory is
GISDBASE.
variable with the
command:
eval g.gisenv
or:
etc.
the mapset
The PERMANENT
created the
location.
mapset for daily
reserved for
regardless of the
current mapset.
in one location,
mapset except
PROJ_UNITS).
Thanks & Regards
Kunal Malik
09871147561
Thanks & Regards
Kunal Malik
09871147561
Jachym Cepicky
Thanks & Regards
Kunal Malik
09871147561
Thanks & Regards
Kunal Malik
09871147561
On Wed, 2008-02-27 at 17:06 +0530, Kunal Malik wrote:
Hi jachym,
Yes you can use the svn (=subversion) tool to download GRASS source code
and the grass-addons as well. Look at
http://trac.osgeo.org/grass/wiki/DownloadSource
Hi jachym,
when i am trying to get the configure svn i m getting the error
Configure: error: no suitable apr found
please see previous mail …i have some more queries in it.
Hi jachym,
Thanks & Regards
Kunal Malik
09871147561
On Tue, Feb 26, 2008 at 2:01 PM, Kunal Malik <kunal.malik81@gmail.com> wrote:
Hi!
I have seen this recently on Ubuntu. After 30min I gave up... some
"sudo" issue which seems to be Ubuntu specific. Could this be
your problem?
