Salut!
I can't explain why the MASK does not affect any
"r.mapcalc" operations any more!
Whatever I do, with a MASK present, the results look like
there is no MASK.
Any "secret" options... (?).
Thank you in advance,
Nikos
Salut!
there is no MASK.
Nikos
OK... I am confused!
(An example) With r.mapcalc I create:
(a) NDVIDIFF0 based on "if(NDVIDIFF > 0, StudyArea_Raster,
null())"
{ Data type and r.describe of NDVIDIFF0: CELL, * 1-23 25-30
32-42 }
(b) and NDVIDIFF0_fromNDVI based on "if(NDVIDIFF > 0,
NDVIDIFF, null())"
{ Data type and r.descrive of NDVIDIFF0_fromNDVI: DCELL, *
0.000000-0.636731 0.642682-0.702189 0.714091-0.743845
0.749795-0.755746
1.309167-1.315117 1.315117-1.321068 1.451985-1.457936
1.511492-1.517443 }
Creating the MASK with r.mask or with r.mapcalc=MASK based
on (a) is always successful. Creating the MASK with (b) is
not what I expect and, in addition, it gives different
results when using r.mapcalc MASK=... instead of r.mask.
Do the DCELL values of (b) affect the process... ?
Thank you,
Nikos.
I still can't explain why I can't create a mask with the following raster:
| Layer: NDVI20060.35 Date: Tue Jan 22 13:53:02 2008
| Mapset: nik Login of Creator: nik
| DataBase: /home/nik/grassWorks/Peloponnese_DamageAssessment2007
| Title: ( NDVI20060.35 )
| Timestamp: none
| Type of Map: raster Number of Categories: 255
| Data Type: DCELL
| Rows: 1048
| Columns: 972
| Total Cells: 1018656
| Projection: Transverse Mercator
| N: 4255830 S: 3993750 Res: 250.07633588
| E: 468810 W: 225720 Res: 250.09259259
| Range of data: min = 0.001304 max = 0.349991
| Data Description:
| generated by r.mapcalc
| Comments:
| if((NDVI2006 > 0 && NDVI2006 < 0.350000), NDVI2006, null())
Whenever I "r.mask input=NDVI20060.35" or with "rmapcalc MASK=NDVI20060.35",
I get nothing when I try to view or to use r.mapcalc on others rasters.
Any ideas about this?
Thank you,
Nikos
View this message in context: http://www.nabble.com/MASK-does-not-do-it's-work-(-)-with-r.mapcalc-tp14407246p15018501.html
| Layer: NDVI20060.35 Date: Tue Jan 22 13:53:02 2008 |
| Mapset: nik Login of Creator: nik |
| DataBase: /home/nik/grassWorks/Peloponnese_DamageAssessment2007 |
| Title: ( NDVI20060.35 ) |
| Timestamp: none ||----------------------------------------------------------------------------|
| Type of Map: raster Number of Categories: 255 |
| Data Type: DCELL |
| Rows: 1048 |
| Columns: 972 |
| Total Cells: 1018656 |
| Projection: Transverse Mercator |
| N: 4255830 S: 3993750 Res: 250.07633588 |
| E: 468810 W: 225720 Res: 250.09259259 |
| Range of data: min = 0.001304 max = 0.349991 |
| Data Description: |
| generated by r.mapcalc |
| Comments: |
| if((NDVI2006 > 0 && NDVI2006 < 0.350000), NDVI2006, null()) |
I get nothing when I try to view or to use r.mapcalc on others rasters.Any ideas about this?
Maybe the value of the MASK map has to be 1 ? I see that your MASK varies from 0.001304 to 0.349991.
Moritz
Thank you for the attention Moritz.
I understand MASK as a boolean map with (let's say) "1"
(for true) and "0" (for false).
The r.info (the one I provided in my previous e-mail) is
about the raster data I want to use to create a MASK and
not the MASK itself.
Should I understand that only "integer" raster data are
suitable to create a MASK?
I understand (reading the r.mapcalc functionality) that one
can use any kind of raster data (floating point) and create
a MASK which contains a "1" for the pixels that have any
value besides "NULL".
So I expected to have a "1" wherever there was a value in
my NDVI2006 file.
Maybe I use it wrong(?)
Should I specify to assign a value of "1" for all non-NULL
source pixels?
I'll try with "mask = a != 0" as described in the r.mapcalc
manual.
Nikos
(for true) and "0" (for false).The r.info (the one I provided in my previous e-mail) is
not the MASK itself.Should I understand that only "integer" raster data are
The mask is read as an integer map. If MASK is actually a
floating-point map, the values will be converted to integers using the
map's quantisation rules (this defaults to round-to-nearest, but can
be changed with r.quant).
Your NDVI20060.35 map has a range of 0.001304 to 0.349991, so all of
those values will be rounded to zero.
value besides "NULL".So I expected to have a "1" wherever there was a value in
my NDVI2006 file.Maybe I use it wrong(?)
source pixels?I'll try with "mask = a != 0" as described in the r.mapcalc
manual.
If you want to create a mask based upon null/non-null, use e.g.:
r.mapcalc "MASK = !isnull(inmap)"
Thanks for the important clarification.
Do you think it would be useful to add this information in the manual of
r.mask?
> suitable to create a MASK?The mask is read as an integer map. If MASK is actually a
be changed with r.quant).Your NDVI20060.35 map has a range of 0.001304 to 0.349991, so all of
those values will be rounded to zero.> I understand (reading the r.mapcalc functionality) that one
> my NDVI2006 file.
> source pixels?
> manual.If you want to create a mask based upon null/non-null, use e.g.:
Nikos Alexandris
Department of Remote Sensing & Landscape Information Systems
Faculty of Forestry & Environmental Sciences, Albert-Ludwigs-University Freiburg
Tel. +49 (0) 761 203 3697 / Fax. +49 (0) 761 203 3701 / Skype: Nikos.Alexandris
Address: Tennenbacher str. 4, D-79106 Freiburg i. Br., Germany
Glynn:
> the map's quantisation rules (this defaults to round-to-nearest,
> but can be changed with r.quant).
of r.mask?
already added to the MASK section of the 2D-raster intro help page in
6.3svn. It makes some sense to add it to the r.mask help page too.
H
____________________________________________________________________________________
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
of r.mask?
H
r.mask help page updated in svn trunk and grass63_release branch.
~ Eric.
Folks,
(with all the respect) the GRASS community is a phenomenon!
Nikos.
>> of r.mask?>already added to the MASK section of the 2D-raster intro help page in
>Hr.mask help page updated in svn trunk and grass63_release branch.
~ Eric.
Nikos Alexandris
