Hi
I am trying to export maps from Grass 7.0.0 running in Linux (64 bit
Ubuntu) using r.out.mat.
Matlab (R2014b), however, complains that these files are corrupt.
(Matlab is also running in Linux.)
Could anyone please advise?
Many thanks, Kevin
Hi
Many thanks, Kevin
On Thu, Nov 6, 2014 at 2:24 AM, Kevin Williams <zs1kwa@gmail.com> wrote:
Hi
Ubuntu) using r.out.mat.Matlab (R2014b), however, complains that these files are corrupt.
(Matlab is also running in Linux.)Could anyone please advise?
it is possible that r.out.mat supports some older version of these .mat
files which Matlab no longer accepts.
There are some things you can do.
1) Try if you can tell Matlab that it is an older version of the format.
2) Try Octave, perhaps load and save there, then open in Matlab.
3) Try on of the (many) formats provided by r.out.gdal. Can Matlab load
TIFF, for example?
4) Use r.out.ascii (or r.out.xyz) and read the created text file to Matlab
in some way.
5) Fix r.out.mat if you can and submit a patch.
In any case, please share what worked for you.
Vaclav
Many thanks, Kevin
grass-user mailing list
grass-user@lists.osgeo.org
Hi
It does not seem possible to tell Matlab it is a v4 file, but (thanks
for the suggestion) Octave has no problem with it.
I can "re-save" it as a new v4 file from Octave, and then Matlab will load it.
Best regards, Kevin
Hi
files which Matlab no longer accepts.There are some things you can do.
TIFF, for example?
in some way.
5) Fix r.out.mat if you can and submit a patch.In any case, please share what worked for you.
Vaclav
Many thanks, Kevin
