[GRASS-user] matrices of distances in attribute tables
hi all, is there any way to insert the results of the distance matrix “v.distances-pa” in the database attribute points, but not in a single column but a table and each column would be the distance from one point to the other, additionally also like to add the result of “shortestpath pars for all” in the same way, but in the same order as if a distance matrix.
this is to compare how easy or difficult is it to travel from one point to another.
thanks for your answers
Ricardo Rodríguez
Univalle
