[GRASS-user] Max length of sql_query in v.extract
Hello,
Is there a length limit to a "where" sql statement fed to v.extract?
I am getting an
Error in db_open_select_cursor()
in the middle of a very long query.
Thanks for any hints,
Luigi
On Wed, Jan 27, 2010 at 8:35 PM, Luigi Ponti <lponti@infinito.it> wrote:
Hello,
I am getting an
Could you please try to analyse with
g.gisenv set=DEBUG=3
to identify when it gets lost? And perhaps provide an example
based on the Spearfish or North Carolina data sets?
best
Hello,
I am getting an
Version: WinGRASS-6.4.SVN-r40650-1 (installed in C:\GRASS-64-SVN i.e. no spaces in path; OS Windows 7)
Dataset: North Caroline dataset
Mapset: user1
vector: census_wake2000 (this actually resides in PERMANENT)
Working on the "Cmd >" input box of the wxGUI. I have chosen a case analogous to that where I encountered the error, i.e. a DBF Character field containing 105 different numeric codes (e.g. 050100) one per record:
(note that you can find full debug output in a text file available at the following link:
https://docs.google.com/leaf?id=0B0EpsfMZ-IZYOTJiYWVmNjUtNGYzMC00NDM5LWI1NDYtZTMyNzg3M2NjOThk&sort=name&layout=list&num=50
I thought 20,000+ lines was too much for the mailing list but please advice if had better taken a different course of action.)
### START GRASS CMD HISTORY ###
g.gisenv set=DEBUG=3 (Thu Jan 28 12:12:34 2010) Command finished (0 sec) (Thu Jan 28 12:12:43 2010) v.extract input=census_wake2000 output=census_extract_all_trt2000 where=(TRT2000='050100')or(TRT2000='050300')or(TRT2000='050400')or(TRT2000='050500')or(TRT2000='050600')or(TRT2000='050700')or(TRT2000='050800')or(TRT2000='050900')or(TRT2000='051000')or(TRT2000='051100')or(TRT2000='051200')or(TRT2000='051400')or(TRT2000='051501')or(TRT2000='051502')or(TRT2000='051600')or(TRT2000='051700')or(TRT2000='051800')or(TRT2000='051900')or(TRT2000='052001')or(TRT2000='052002')or(TRT2000='052101')or(TRT2000='052102')or(TRT2000='052201')or(TRT2000='052202')or(TRT2000='052301')or(TRT2000='052302')or(TRT2000='052401')or(TRT2000='052402')or(TRT2000='052404')or(TRT2000='052405')or(TRT2000='052501')or(TRT2000='052503')or(TRT2000='052504')or(TRT2000='052601')or(TRT2000='052602')or(TRT2000='052603')or(TRT2000='052701')or(TRT2000='052703')or(TRT2000='052704')or(TRT2000='052705')or(TRT2000='052801')or(TRT2000='052802')or(TRT2000='052803')or(TRT2000='052804')or(TRT2000='052805')or(TRT2000='052900')or(TRT2000='053001')or(TRT2000='053002')or(TRT2000='053101')or(TRT2000='053103')or(TRT2000='053104')or(TRT2000='053200')or(TRT2000='053402')or(TRT2000='053403')or(TRT2000='053404')or(TRT2000='053405')or(TRT2000='053406')or(TRT2000='053407')or(TRT2000='053501')or(TRT2000='053505')or(TRT2000='053506')or(TRT2000='053507')or(TRT2000='053508')or(TRT2000='053509')or(TRT2000='053510')or(TRT2000='053512')or(TRT2000='053513')or(TRT2000='053514')or(TRT2000='053515')or(TRT2000='053600')or(TRT2000='053703')or(TRT2000='053706')or(TRT2000='053707')or(TRT2000='053709')or(TRT2000='053710')or(TRT2000='053711')or(TRT2000='053712')or(TRT2000='053713')or(TRT2000='053714')or(TRT2000='053715')or(TRT2000='053716')or(TRT2000='053801')or(TRT2000='053802')or(TRT2000='053900')or(TRT2000='054001')or(TRT2000='054003')or(TRT2000='054004')or(TRT2000='054006')or(TRT2000='054007')or(TRT2000='054008')or(TRT2000='054009')or(TRT2000='054010')or(TRT2000='054102')or(TRT2000='054104')or(TRT2000='054105')or(TRT2000='054106')or(TRT2000='054107')or(TRT2000='054108')or(TRT2000='054109')or(TRT2000='054201')or(TRT2000='054202')or(TRT2000='054301')or(TRT2000='054302')or(TRT2000='054401')or(TRT2000='054402')
D3/3: Mapset = PERMANENT
D1/3: Vect_open_old(): name = census_wake2000 mapset=
PERMANENT update = 0
D1/3: Vect_set_thresh(): thresh = 0.000000
D3/3: db_select_int()
D3/3: SQL: SELECT cat FROM census_wake2000 WHERE (TRT2000=
'053101')or(TRT
DBMI-DBF driver error:
SQL parser error: syntax error, unexpected $end processing
in statement:
SELECT cat FROM census_wake2000 WHERE (TRT2000='050100')or(T
RT
ERROR: Unable select records from table <census_wake2000>
(Thu Jan 28 12:12:45 2010) Command finished (1 sec)
### END GRASS CMD HISTORY ###
But if I do the same with only the first 10 TRT2000 codes, everything seem to work fine:
mapset= user1
D1/3: get coor info: C:\cygwin\home\andy/nc_spm_08/user1/vec
tor/census_extract_all_trt2000/coor
D2/3: ftell = 6941
D1/3: Info->size = 6941, Info->mtime = 1264679138
D1/3: dig__write_head()
D1/3: write coor size (6941) to head
D2/3: coor body offset 14
D1/3: Vect_get_thresh(): thresh = 0.000000
D1/3: Vect_write_dblinks(): map =
census_extract_all_trt2000, mapset = user1
D1/3: dbln file: C:\cygwin\home\andy/nc_spm_08/user1/vector/
census_extract_all_trt2000/dbln
D1/3: 1 census_extract_all_trt2000 cat
$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/ dbf
D1/3: Dblinks written
(Thu Jan 28 12:45:51 2010) Command finished (13 sec)
And the resulting vector displays ok -- the v.info output is the following:
v.info census_extract_all_trt2000 +----------------------------------------------------------------------------+
| Layer: census_extract_all_trt2000 |
| Mapset: user1 |
| Database: C:\cygwin\home\andy |
| Titolo: Wake County census tracts 2000 (polygon map) |
| Scala della mappa: 1:1 |
| Formato della mappa: native |
| Name of creator: helena |
| Organization: NC OneMap |
| Dati di origine: Tue Nov 7 19:54:38 2006 |
| Type of Map: vector (level: 2) |
| Numero di punti: 0 Numero di aree: 10 |
| Numero di linee: 0 Numero di isolee: 1 |
| Numero di confini: 41 Numero di facce: 0 |
| Numero di centroidi: 10 |
| Map is 3D: No |
| Number of dblinks: 1 |
| Proiezione: Lambert Conformal Conic |
| N: 228616.93548384 S: 222650.82550162 |
| E: 645055.16891034 W: 637287.55397511 |
| Digitization threshold: 0 |
| Comments: |
(Thu Jan 28 13:12:03 2010) Command finished (0 sec)
Kind regards,
Luigi
best
Hello,
I am getting an
Mapset: user1
following link:
where=
[... very long WHERE suppressed...]
... first part of very long statement...
'053101')or(TRT
This looks suspicious:
lib/dbmi/dbmi_client/select.c
int db_select_int(dbDriver * driver, const char *tab, const char *col,
                  const char *where, int **pval)
    int type, more, alloc, count;
    int *val;
    char buf[1024];
    /* allocate */
    alloc = 1000;
    val = (int *)G_malloc(alloc * sizeof(int));
    if (where == NULL || strlen(where) == 0)
        G_snprintf(buf, 1023, "SELECT %s FROM %s", col, tab);
    else
        G_snprintf(buf, 1023, "SELECT %s FROM %s WHERE %s", col, tab, where);
    G_debug(3, " SQL: %s", buf);
    db_init_string(&stmt);
    db_append_string(&stmt, buf);
I guess that we need to change to dynamic string length allocation here?
The cut string is pretty close to the 1023 chars length.
Not sure why this happens, but some of the manual pages of my WinGRASS-6.4.SVN-r40650-1 installation are in English e.g.
v.build.all - Rebuilds topology on all vector maps in the current mapset.
while other are in another (not sure which) language e.g.
v.buffer - Vytvoøí buffer okolo prvkù zadaného typu (plochy musí obsahovat centroid)
Is this a known issue?
Kind regards,
Luigi
Thanks for your answer, Markus.
Hello,
I am getting an
where=
Yes, that's very long. Would there be a better way of achieving this in GRASS e.g. via *.db.* commands or is v.extract a wrapper for them, and hence they would fail anyway?
Kind regards,
Luigi
Martin: please read on:
On Thu, Jan 28, 2010 at 3:27 PM, Luigi Ponti <lponti@infinito.it> wrote:
centroid)
It is a bugfeature: some want it some not. Ideally both English and the
current locale would be used for creating the manual, see enhancement
request: https://trac.osgeo.org/grass/ticket/846
Apparently winGRASS-daily was/is build in CZ locale and NLS active.
Before compilation, the locale settings should be set to English by
defining LANG and LC_MESSAGES variables. IMHO easy to fix
on Martin's server.
    else
AFAICT, the raison d'être for the dbString type was precisely to avoid
this sort of issue. I suggest:
  db_append_string(&stmt, "SELECT ");
  db_append_string(&stmt, col);
  db_append_string(&stmt, " FROM ");
  db_append_string(&stmt, tab);
  if (where && *where) {
      db_append_string(&stmt, " WHERE ");
      db_append_string(&stmt, where);
Beyond that, maybe we need db_sprintf_string()?
BTW, as we appear to be taking the availability of snprintf() for
granted, maybe it's time to re-write G_asprintf() (the current
fallback implementation where vasprintf() isn't available writes to a
temporary file then reads it back in, which isn't exactly efficient).
v.buffer - Vytvoĝí buffer okolo prvkù zadaného typu (plochy musí obsahovat
centroid)
request: [https://trac.osgeo.org/grass/ticket/846](https://trac.osgeo.org/grass/ticket/846)
on Martin's server.
Hello,
Just wanted to mention the partly-Czech manual is still there on the daily standalone installer (WinGRASS-6.4.SVN-r40876): many (not all) of the man pages have the first part (Flags, Parameters) in Czech, while starting from the Description section the rest of the page is in English.
Kind regards,
Luigi
P.S. It was really a major improvement to have daily builds packaged for windows – THANKS!
2010/1/28 Markus Neteler <neteler@osgeo.org>:
on Martin's server.
finally I have some time to look at this problem. Defining LANG and
LC_MESSAGES in package.sh doesn't seems to help. Any hint from Windows
users?
Thanks, Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
On Thu, Feb 11, 2010 at 10:52 AM, Martin Landa <landa.martin@gmail.com> wrote:
on Martin's server.
users?
Two random ideas:
- add the definitions also in the cronjob script
- check if English language is possible on the machine (maybe the
en_US locale isn't there?)
>> on Martin's server.
> users?
Two random ideas:
The default locale is "C", which behaves the same as if no locale is
set (i.e. no call to setlocale()).
LC_ALL takes precedence over the individual LC_* variables and LANG,
so you may need to use:
  export LC_ALL=C
2010/2/18 Glynn Clements <glynn@gclements.plus.com>:
   export LC\_ALL=C
I have already tried to put `LC_ALL=C` to package.sh and recompile
GRASS, but it didn't seem to help (module --interface-description
still returns localized text).
Martin
Thanks Martin. Just to detail further my report, in case it is useful (sorry if redundant):
Installed last available WinGRASS-6.4.SVN-r41105-1-Setup.exe of 19 February.
If I do for example:
r.colors --interface-description
what is get is:
<?xml version="1.0" encoding="CP1252"?> Creates/modifies the color table associated with a raster map layer. raster, color table Nome della mappa raster in input name Required [...]
You can see there is English description plus some Italian text depending on how far the translator got. It is the same text I get in the g.parser GUI when invoking r.colors without arguments. I think this is fine since I have an Italian locale. However, the HTML manual page of r.colors is a partial Czech translation.
Kind regards,
Luigi
