So, here are my experiences with v.path thought the weekend:
I have installed grass 7.3 and used v.path with Z flag. I have notice that almost all of my boreholes (I am working with 3d boreholes) was correctly placed, but a few (around 10 of 110) wasn’t. First I think about wrong field data.
But then I tried to merge then in another way:
I have generated 1 shape file for each borehole using v.out.ogr and merge then using Qgis. It worked beautifuly. So I am writing this because it may have an error on v.path or maybe an error on my thinking line. Either way I present a workaround for anyone there that may interest.
I can provide my workdata for anyone one grass develop team for v.path validation, you just have to ask =)
best regards for you all,
Alec Ventura.
De: grass-user grass-user-bounces@lists.osgeo.org em nome de Rich Shepard rshepard@appl-ecosys.com
Enviado: sexta-feira, 30 de setembro de 2016 09:59
Para: grass-user@lists.osgeo.org
Assunto: Re: [GRASS-user] ‘Maximum vector line maps loaded’
On Fri, 30 Sep 2016, Alec Ventura wrote:
Yeah, I notice that changes on v.patch, but I kind aprehensive to download
7.2 version because the download link was with a line through it, like it
was deprecated or something =P.
I will try 7.3 that is in development.
Alec,
I have no problems running 7.0. 7.2, or 7.3 checked out from the
subversion repositories. They download, build, and run just fine.
Use 7.3.svn unless something doesn’t work, then repeat with 7.2.svn.
Rich
grass-user mailing list
