[GRASS-user] maximum zoom-in reached
Grass 6.3.0 on Ubuntu, give me "maximum zoom-in reached", when I tried
to zoom in to city level of data of shapefile of Indian highways
(taken from openstreetmap).
Is there any limit to zoom-in for vector files. If yes, how to reset it?
Thanks in advance.
H.S.Rai
Please check the region's raster resolution settings, it could be
related in terms of zooming.
City level should definitely not be a problem.
gis.m gives "Maximum zoom-in reached" error when display width/height
is smaller than one column/row. If You have data with higher
resolution, You have to adjust Your region settings (increase
resolution). See g.region how to set resolution.
Maris.
2008/11/29, H. S. Rai <hardeep.rai@gmail.com>:
Thanks in advance.
H.S.Rai
grass-user mailing list
grass-user@lists.osgeo.org
in d.zoom is some related magic:
display/d.zoom/set.c
            fprintf(stderr, "\nResolution is too low for selected region.\n");
            fprintf(stderr, "Buttons:\n");
            fprintf(stderr,
                    "Left: Increase resolution to n-s = %g e-w = %g\n", nsr,
                    ewr);
            fprintf(stderr, "Middle: Cancel (keep previous region)\n");
            fprintf(stderr, "Right: Cancel (keep previous region)\n");
Maybe something similar is missing in gis.m?
In such case gis.m will emit just an warning and not change region.
Feel free to change message:
https://trac.osgeo.org/grass/browser/grass/branches/develbranch_6/gui/tcltk/gis.m/mapcanvas.tcl#L526
Maris.
2008/11/29, Markus Neteler <neteler@osgeo.org>:
region.\n");
            fprintf(stderr,
nsr,
                    ewr);
Thanks to all for prompt and appropriate responses. Default region was
with resolution 1. I anticipated this and changed to .0001, but may be
I was not able to do it properly, and was not able to get zoom in.
Then I existing GRASS, restarted, and it worked fine.
$ g.region -p
projection: 1 (UTM)
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 36.56820636
south: 6.09470106
west: 66.77269446
east: 98.66413062
nsres: 0.0001
ewres: 0.0001
rows: 304735
cols: 318914
cells: 97184257790
H.S.Rai
H.S.Rai wrote:
$ g.region -p
rows: 304735
cols: 318914
cells: 97184257790
It is not advisable to stay in a region of that size for very long, and
definitely don't try any raster ops. Note that most vector modules don't
care about the region settings, but d.zoom and friends must consider it.
While there is no set max (depends on how huge your hardware is) for me
25000x25000 is near the upper usable limit for raster maps on my P4.
Hamish
On Sun, Nov 30, 2008 at 8:08 AM, Hamish <hamish_b@yahoo.com> wrote:
H.S.Rai wrote:
$ g.region -p
rows: 304735
cols: 318914
cells: 97184257790
<snip>
Thanks for your advise and concern.
H.S.Rai
