[GRASS-user] memory requirement of v.net.allpairs module
Dear Developers and users,
On a small test region (11000x11000 cells), with a threshold of 1000sqkm, r.stream.extract resulted in a stream vector network of 190 points and lines. The v.net.allpairs generated a table of distances between each point within 10 seconds on my home machine (only 4gb ram). I thought that I got my solution for finding sub-basins of a very large area. (Please refer to my earlier posts in this regard.)
On my work setup, (better machine, 16gb RAM , six cores), I followed this routine:
  1. r.grow by one cell on area of interest. (It’s an important step. Thanks to Markus Metz for this tip.) Time taken by the module: approximately 2 hours.
  2. r.stream.extract on my area of interest.(42000*42000 cells) with 100 sq.km. as threshold (12345 in number of cells.)
    Please note that the r.stream.extract module’s vector output was a network of 1,45,000 (approx) points and lines.
    Time taken by module: approximately 24 hours.
  3. Then I ran “v.net.allpairs” on this network. Now, v.net.allpairs is still running. Approximately, one week has elapsed.
    After three days, a message appeared on the console that says “writing data into the table”. After four days of this message, the progress bar is still without any colour. ( Which I consider as progress being less than one percent.)
The other thing which I noticed was the memory consumption. The module has consumed 15.5 gb ram out of 16gb, thereafter it consumed 166gb of swap space out of 500gb swap space available.( Earlier, I had kept complete one disk of 1 tb for swap.)
Some of the answers for this response of the module, I have myself.
Like, the module has more calculations to do. (145000145000)/(190190)~582410.
Still, as per my calculation of time required 58241010 seconds/(2460*60)~ 6.75 days
And, I should have my postgres table ready for further calculations.
But, still there is no sign of any progress.
Is the time and memory being consumed by the module as per design and ok.
I can definitely sub-divide into basins and work further.
