I have a couple of vector layers with similar attribute tables and want to
merge them (as v.merge did in Grass5). I tried v.overlay with operator OR,
but this handles only two layers and does not merge the attributes lables
(label xxx in layer a becomes label a_xxx and label xxx in layer b becomes
label b_xxx instead of merging attributes from both layers under the label
xxx). What else can I try? Thanks for any help,
Typical! Just posted and I got it. v.patch works fine ...
On Wed, 03 Oct 2007 12:00:46 +0000, Henning Lorenz wrote:
Hi!
