All:
I have the national hydrography dataset plus [NHDPlus]. The data came with a rather limited table of information by design. I would like to add a table with stream line attributes to the vector table. There is a common ID called COMID. I just want to merge the two tables together on COMID. How do I do this? I have thought of just merging the two tables together pre-import? Many thanks for any help.
Stephen Sefick
Auburn University
Biological Sciences
331 Funchess Hall
Auburn, Alabama
36849
sas0025@auburn.edu
http://www.auburn.edu/~sas0025
Let's not spend our time and resources thinking about things that are so little or so large that all they really do for us is puff us up and make us feel like gods. We are mammals, and have not exhausted the annoying little problems of being mammals.
-K. Mullis
"A big computer, a complex algorithm and a long time does not equal science."
-Robert Gentleman
The data table I would like to merge is in .dbf format.
many thanks,
Stephen Sefick
Auburn University
Biological Sciences
331 Funchess Hall
Auburn, Alabama
36849
sas0025@auburn.edu
-K. Mullis
-Robert Gentleman
On 01/02/12 13:42, Stephen Sefick wrote:
All:
Try db.in.ogr + v.db.join in a mapset with an SQL backend, e.g. SQLite instead of dbf.
Moritz
Thanks for the help. What I ended up doing is reading the .dbf files into R with the foreign packages read.dbf; merged the data together on the COMID; wrote out the data with write.dbf; connected it to the vector with v.db.connect; and all is well. Again many thanks for your help.
Stephen
All:
Moritz
grass-user mailing list
grass-user@lists.osgeo.org
Stephen Sefick
Auburn University Biological Sciences 331 Funchess Hall Auburn, Alabama 36849 **************************************************
sas0025@auburn.edu http://www.auburn.edu/~sas0025 **************************************************
-K. Mullis
-Robert Gentleman
