You may use r.info to obtain the coordinates of the opposite
corners of the grid of the raster map. Alternatively, you could
change the current region to the one of the raster map ($
g.region rast=MAP), then print it ($ g.region -p.) (You're to
save the current region to a temporary file to be able to return
to it.)
The above gives you the coordinates of the corners of the grid.
I know no easy way to obtain the coordinates of the corners of
the actual data (i. e., with the NULLs omitted.)
to it.)
You can use "g.region zoom=..." for this.
The rast= option uses the bounds of the map itself, while zoom= uses
the smallest rectangle which encloses all of the non-null cells.
I want to get min and max coord values from of catagorized raster
map.
something like: r.stats -agn hey6 > gives minx maxx miny maxy
is it possible ?
do you mean you want the coordinates of the bounding boxes surrounding
each category?
loop over each CAT (`r.describe`), create a MASK or new map based on
that cat, then 'g.region -p zoom='.
Hamish
thank you and other friends
I wrote a script to calculate the coordinates of bounding box of each category using "g.region -p zoom="
I am wondering if "r.stats -agn" is second alternative ?
My raster map is something like some islands.
if I get coord value of each category , I can calculate most north- south and, most west- east, and then determine the coords of minimum bounding box?
As far as I see, g.region gives only perpendicular bounding box.
regards
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
>> map.
>> is it possible ?
> each category?
bounding box?
This is more efficient, particularly for many categories, but it
requires a bit more work. The attached script takes the output from
"r.stats -gn" and computes the bounding boxes for each category, e.g.:
map.
is it possible ?
each category?
#!/usr/bin/awk -f
if ($3 in n)
if (n[$3] < $2) n[$3] = $2
if (s[$3] > $2) s[$3] = $2
if (e[$3] < $1) e[$3] = $1
if (w[$3] > $1) w[$3] = $1
else
n[$3] = s[$3] = $2
e[$3] = w[$3] = $1
END {
for (i in e)
print i,n[i],s[i],e[i],w[i]
Thank you again
I preferred r.stats, because its output more is manageable than g.region's in terms of querying.
The awk script solved the issue practically.
I was thinking to port the data to postgresql to find min, max coord values for each category.
By the way just an idea:
can "g.region zoom=" work with respect to cat value of a map in grass's future releases ?
regards
